04-10-2006, 07:37 PM
i just got new tires for the alero 245/40/18 and when i lower the car the rear tires rub a bit
can i lean in the rear tires to clear the wheel whells and how much is ok to do?
04-10-2006, 07:49 PM
perhaps you'll need some spacers
with a 245 you really should have gone like 35 series rubber..245/35 18
Brent: and in the end...... cherrington is still a cum dumpster whose closest contact with HOT women is through a car internet forum ........... so as long as we can agree on that........ we can all go back to being friends.
Being Brents friend is teh hotness
04-10-2006, 07:56 PM
derek he has airbags........
only thing u might be able to do is get a rim that is more narrow. i run 18x8 and i cant lower the car all the way and drive....... i rub on my fenderwells also
joelsoundxtreme: u faggot
04-10-2006, 10:04 PM
ahh i forgot..my bad
04-11-2006, 11:20 AM
y didnt you get 225/40/18 tires
04-11-2006, 01:57 PM
ya i was about to say the same. But apparently people here love sidewall for some reason. LOL
04-11-2006, 02:15 PM
Originally posted by AftermathAlero+Apr 11 2006, 10:57 AM--><div class='quotetop'>QUOTE(AftermathAlero @ Apr 11 2006, 10:57 AM)</div><div class='quotemain'><!--QuoteBegin-pimpalero2003@Apr 11 2006, 09:20 AM
[/b][/quote]
Sidewall???? You mean WWIIIDDDEEE tires??? :P
1.3l Renesis Rotary
04-11-2006, 03:37 PM
noo, a 245/40 18 has considerable more sidewall as well as width. 40 only implies 40% of the width makes up the sidewall. soo 225 times .40 is less than 245 times .40.
and this added sidewall means a taller tire, which explains why he cant drop the car lower
04-11-2006, 04:07 PM
ya but see hes talkin bout being able to drive the car with the bags extremely low it sounds like.
no matter how thin a tire u put on i think its gonna rub depending on the width of the rim.
like i said i have 8inch wide rims and i cant drive tuckin tire in the back without rubbing
04-11-2006, 04:38 PM
from what i've heard its not the best idea to drive around riding low anyway..
04-11-2006, 05:04 PM
but its pimp
04-11-2006, 06:06 PM
I Have ONE NUT
I cant slam the ho either without rubbing because of the fender well. Just have to raise it up a bit and rollout.
04-11-2006, 10:13 PM
i never noticed u were on air befor nosweat. what kinda bags u got?
04-12-2006, 12:21 AM
actuley the passangerside is not aligned right i took it to a body shop and they said they can pull the lip a bit the reason i went with the 245 is so the tire covers up the lip of the rim i am thinking of getting them for the front but i would have to rool the lip of the front fender.
i have easy street bags with a 5 gallon tank and 2 viar 450 compressors the digital air mgment and 1/2 up and 3/8 down
i installed it all my self and the hardest part is getting rid of the leaks i lose about 1 psi an hour on all my bags due i am not good at pipe fittings
04-13-2006, 12:03 AM
you spray it all down? ptc fittings and everything? be generous with the poop, i used dish soap.
04-13-2006, 12:15 AM
last i knew he is on air ride tech
04-13-2006, 01:02 AM
what did u use to seal the valves and fittings? teflon tape or the wet sealant stuff?
i only have one leak in one rear back but i havent tried to locate it yet
04-13-2006, 01:40 AM
i know where the leaks are but i have about 6 so i have to rip all the valves off and i just havent found the warm weather to do it. i used tape and this is my first atempt at using tape and pope thread fittings.
no sweat do you have 245 on the front and how dues that work ? are they inside the fender wells?
04-13-2006, 02:02 AM
thread sealant works better than thread tape sealant, but I actually had really good results with the tape.
04-13-2006, 10:01 AM
I Have ONE NUT
Originally posted by ppgnut+Apr 13 2006, 04:15 AM--><div class='quotetop'>QUOTE(ppgnut @ Apr 13 2006, 04:15 AM)</div><div class='quotemain'><!--QuoteBegin-SweetNLow@Apr 11 2006, 09:13 PM
[/b][/quote]
That's right. It's the ride pro-e kit.
Hey, Slow I wanted to tuck a litte rubber so to make sure of it I went with nitto 225/40/18's
