Old 04-14-2006, 01:33 PM   #1
Str33tRacer
i have 6 switches hooked up below by deck. Theyre all 3 prong blue glowing that i bought from home depot. Im having problems getting them to work tho. The switch is POWER GROUND ACC. what im stuck with is what the ACC is. what wire of my neons do i attach to that prong. the positive?
Old 04-14-2006, 06:26 PM   #2
brim
brim's Avatar
pos of the neons to acc. and constant power from a 12v source to the main power, then ground the last of course
smirking is important
follow the titans
Old 04-14-2006, 06:55 PM   #3
alerocar01
alerocar01's Avatar
alerocar01 is an unknown quantity at this point
x2
DO WORK
alerocar01 is offline   Reply With Quote
Old 04-14-2006, 08:13 PM   #4
Str33tRacer
i did that exact thing and it didnt seem to work. What do i do to the Neg. wire of the neons just tape it off?
Old 04-14-2006, 08:33 PM   #5
AftermathAlero
might be obvious to ground the neg of the neons. The ground on the switch is to light up the LED in it when its turned on. Thats your problem with it not working.
Old 04-15-2006, 01:44 AM   #6
sound_xtreme
sound_xtreme's Avatar
Originally posted by AftermathAlero+Apr 14 2006, 07:33 PM--><div class='quotetop'>QUOTE(AftermathAlero @ Apr 14 2006, 07:33 PM)</div><div class='quotemain'><!--QuoteBegin-Str33tRacer@Apr 14 2006, 06:13 PM
[/b][/quote]
werd, ground always goes to chassis
Cardomain
Old 04-16-2006, 11:51 PM   #7
Str33tRacer
so i have to ground both the neon negative, and switch negative to the chassis
Old 04-17-2006, 02:14 AM   #8
AftermathAlero
YUP! you got it.
Old 04-18-2006, 09:40 PM   #9
Str33tRacer
will it work if my neon negative is on the terminal as well. instead of running it parallel to the ground to the chassis
Old 04-21-2006, 02:15 PM   #10
BRalero01
no dude you're making this way to hard on yourself. loosen a screw in your fuse box, put BOTH ground wires under the washer and tighten it down. takes 45 seconds
Old 04-21-2006, 09:50 PM   #11
Silentalero
Kitteh is back!!!!
Silentalero's Avatar
and btw to save yourself a huge headache, take the 3 grounds from the switch panel and daisy chain them into each other so your only running 1 wire out
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
Old 04-21-2006, 10:40 PM   #12
brim
brim's Avatar
what silent said, same deal, ground is ground
I used to have one common ground, and then run a wire up into a splitter which could fit about five more wires, then ground the accessories off of that
follow the titans
Old 05-01-2006, 12:57 PM   #13
kaularo88
i just hooked the pos and neg to the aux. cig lighter and connected them to a swithch on the side of the center console, worked good the first time, and every time
