Go Back   Aleromod.com > Performance Related > At The Track
Old 04-16-2006, 11:29 PM   #1
Frostbite545
Frostbite545's Avatar
Frostbite545 is an unknown quantity at this point
Send a message via AIM to Frostbite545
So yeah, the one on the left was my first ever 1/4 mile run against an older mustang. The one on the right was my better time, against some kind of acura hatchback that i beat.
I do have a question though. A stock Alero 3.4 V6 runs a 15.8, and i got a 15.395 with only a Dr. Speed CAI and some Yokohama V4 tires as mods, if u count tires.
Is this a normal gain, i mean, a half second off a 1/4 mile time just by adding 10 or less HP at the flywheel?
- (2000 GL) 14.748 @ 93.04
- Doctor Speed Cold Air Intake
- DHP PCM / 180* Tstat
- General Exclaim UHP Tires
- 2 1/2" Pacesetter Exhaust
- S&S Headers
Frostbite545 is offline   Reply With Quote
Old 04-16-2006, 11:32 PM   #2
yup, and I might say that's a pretty decent gain overall. You have to put in serious power-adders to drop full seconds.
Keep in mind, forced induction will only drop about 2 seconds off 1/4 times with the limited tranny builds that most people are doing.
Old 04-17-2006, 05:30 AM   #3
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
2 seconds would be enough for him in that class!
Good job on the low 10's in the 1/8. I'm still trying to break into 10's...
(nearest quarter track is like 100 miles away.)
Old 04-17-2006, 08:20 AM   #4
Coupe
I wouldnt say you gained anything from the CAI and tires....well the tires may have helped your launch.
GA's and Alero's run between 15.3- 15.9 stock. It depends on alot of factors. Some are just factory freaks. There have been a few GA's run 15 flat completely stock, not common but happens.
Old 04-18-2006, 05:56 PM   #5
Frostbite545
So.....I guess I got a faster Alero by chance. Cool. After all, it was my SECOND RUN EVER, and my reaction time wasn't good (.588). Distracted by the people mocking my alero to my left, I launched At the green light...not 3rd amber like I was supposed to.
- S&S Headers
Old 04-18-2006, 05:59 PM   #6
AlbinoMonkeyRat
Let's Play Army!
.588 is still really good, considering that .499 is a foul.
Old 04-18-2006, 06:07 PM   #7
Frostbite545
.499 is a foul huh? Is it just because they know u had to have launched before green if u get below a .5 ?
I thought i remembered reading about all these other people on this site who go for like .0-somethings as R/T.
(Oh, and I just remembered, it was freezing out that night, like 30-32 degrees. I think that helped my time a little.)
- S&S Headers
Old 04-18-2006, 06:49 PM   #8
freakout
freakout's Avatar
freakout is an unknown quantity at this point
I might be wrong. But I think, the R/T has something to due with the different lights on the tree. They changed from incadesant to l.e.d.. If I am wrong please let me know!
freakout is offline   Reply With Quote
Old 04-18-2006, 06:56 PM   #9
AlbinoMonkeyRat
Let's Play Army!
what kind of lights they use have nothing to do with it...it's when they light up vs when you go. With a slower car like mine, I punched it when it was on the 2nd (middle) yellow, and I get R/Ts that are between .57x and .62x. It's really a matter of technique.
Old 04-18-2006, 07:08 PM   #10
freakout
freakout's Avatar
Oh yeah good run with the car your r/t will get better. R/T used to be .500 perfect now it's .000 is what I wanted to clear up.
Old 04-18-2006, 07:50 PM   #11
AlbinoMonkeyRat
Let's Play Army!
no...a perfect R/T is .500
http://www.irwindalespeedway.com/dra...ite/howto.html
Old 04-18-2006, 10:23 PM   #12
Frostbite545
I think the cecil county dragstrip doesnt care how low your RT is cause the mustang I ran against the 1st time had a RT of .284, and I saw no red lights...
Anyway, I will update this when, hopefully, I blow some Graduation money on S&S headers and a SLP exhaust this summer. My dream is to get into the 14s, even if its a 14.999, just to say I did it in an ALERO.
- S&S Headers
Old 04-18-2006, 10:30 PM   #13
Daytona
ALEROMOD RAPIST
Daytona's Avatar
Daytona is on a distinguished road
A perfect light can be either .500 or .000, depending on the timing system version the track is using. It used to be .500 at RP before we upgraded to the latest timing system 2 seasons ago, at which time .000 became a perfect light. The LED's didn't get installed at our track until a few months later.
You'll find that all tracks that run NHRA Division and National Event races will have .000 as a perfect light. Other tracks might still have .500 systems.
Now to totally confuse the matter, Pro Trees on the old system use .400 as a perfect light, but .000 on the new system. Why .4 instead of .5? No idea. But it's moot now in the new timing systems.
Daytona is offline   Reply With Quote
Old 04-18-2006, 10:32 PM   #14
Daytona
ALEROMOD RAPIST
Daytona's Avatar
Cecil County runs .000 as a perfect light. The .284 equates to a .784 under the old system.
Old 04-18-2006, 10:39 PM   #15
Frostbite545
So, if I am understanding this correctly, my .588 at Cecil, because they use .000 as a perfect time, was prety bad right?
If so, I'm goin back like....friday, because its on. I need to know what I could do if I have a good RT.
- S&S Headers
Old 04-18-2006, 10:53 PM   #16
Daytona
ALEROMOD RAPIST
Daytona's Avatar
Correct, you're RT was pretty slow. RT's do NOT affect ET's, however. Reaction Times simply meausre how soon after the green light comes on that your car breaks the starting timing beam. The ET clock doesn't start until your car launches and breaks the starting timing beam.
In essence, you could sit there at the line for 10 seconds after the greenlight comes on and then launch and your ET will be the same as if you had made that same run the moment the light went green.
If you want to improve on your RT's, hit the gas and release the brake the moment the 3rd amber comes on. By the time your body reacts to the light and the car reacts to your foot the green light should be coming on as your car finally moves.
The more you race the more you'll learn how to time your launch. Each car and driver is different. My 12-second RWD Camaro required a different launch RPM, spot on the starting tree, and positioning at the starting line than my 16-second FWD Daytona. To further cut down your RT you could do like I do with my Daytona and that's to "Deep Stage", which is where you roll up a little further at the starting line so that the top Pre-Stage bulb shuts off. You run a greater risk of going red but if the sweet spot on the tree for your car dictates this you can do very well. Just remember that since you are starting further forward than normal staging your ET's and top-end MPH will be slower since you won't be getting as much of a running start before your break the beams.
For now, though, I'd say to hold off Deep Staging and just stage normally. If your car is an automatic trasmission, launch it at least 200 RPM below your stall speed. If you don't know your convertor's stall speed, then launch @ 1100 RPM. You never want to launch your car at or above your stall speed regardless of whether it's stock or highly modified. Follow this rule and your launches will be a lot more consistent and a little quicker. You might have to adjust you timing off the tree if you start launching at a different RPM than you're used to so worry about your launches first and then once you have that down pat then worry about where on the tree you need to launch to get those tight RT's.
Old 04-18-2006, 11:06 PM   #17
Frostbite545
Sweeeeeet. Thanks for that. I will def. think about this the next time I go to the track.
Hopefully I get more than 2 runs in though. Its so unfulfilling.
- S&S Headers
Old 04-19-2006, 03:43 AM   #18
Spy
there tends to be a difference too whether the tree is setup sportsman (amber amber amber green) or pro (amber green).... which also has to play on how they determine the "reaction" system.
Old 04-19-2006, 04:27 AM   #19
FormulaNERD
yea, i'd race brackets @ sportsman, then get my ass handed to me later during the free for all because it was a pro style tree and i was used to running sportsman twice a week
Old 04-19-2006, 07:17 AM   #20
AlbinoMonkeyRat
Let's Play Army!
FYI: looking closely at my slips from saturday, R/T does factor in who wins in a heads-up race. I was racing a 3.1L Lumina. He had me most of the way down the strip, but I pulled ahead of him right at the end. his ET beat mine by .02 but my RT beat his by .03 so I won. (in heads up, everything counts. I crossed the finish line first and won by .004)
(also, that was my slowest ET, with my fastest mph...which I don't get...)
