Originally posted by elitecloud@Apr 17 2006, 02:50 AM
what's the difference between the two? which one will provide better sound quality? deeper bass?
mostly which is cheaper? lol
will alpine type r's all the way around work good?
Well the main difference is that coax have the tweeter attached to the woofer in some way. where as with componets the tweeter is completly seperate giving you the ability to mount it in a better posistion. This will allow you to get better imaging, therefore giving you a better sound. both have potential for "deep bass", but neither will give you the deep bass you want. for that you neeed a sub.
as for which is cheaper, Id say most likely the coax will be cheaper, but that is probably not true in all cases.
the alpines should do just fine.
It all comes down to what sounds good to you. I suggest you hop in as many cars as possible with aftermarket systems and configuarionts if you want to get an idea of what you like. or if you have the time and money start swaping speakers.
