04-27-2006, 10:31 AM
so here's the deal, in most of my cars i usually keep the stock head unit for a stock look, and just add an amp and some subs.
anyways, i finally found a good HU that matches my interior (Kenwood Excelon KDC-X990 )
so yea, it has 3 outputs for amps, and i'm wondering whats the best way to hook up a 4 ch for 4 soundstream 6.5"s. or would i be better off with 2 2ch amps? and then what do i do about my tweets? let the stock system power them? (front and rears both have tweets)
so do i run a 5v out to each amp or what?
also whats the best way to get the most out of a DVC sub?
if mikegett or someone with a little knowledge could chime in it would be helpful.
04-27-2006, 10:33 AM
oh, its also gonna be a pain ebcause i have a stock monsoon system (not an alero though)
04-27-2006, 01:17 PM
Well, if you're adding amps for all the speakers it should be the same install monsoon or not. The only place the monsoon becomes a little of a headache is if you're looking to use the headunit to power any of the speakers. In that case you'd just need to bypalss the amp. Sometimes plug-in harnesses are made for this purpose, for the others you just have to disconnect the plug(s) on the amp(s) and just route the input wires to the output wires and all should be well and good. Unelss you want to run new wires that is. I'm sure replacing that Monsoon setup would be easier than dealing with the Mach 1000 system in my dad's mustang (2 10s stock! it's crazy).
I don't really think that a 4ch amp makes a difference over 2x2ch amps, the 4ch amp usually just has two separate 2ch amps in it, just do whatever fits better in your car.
As for getting the most out of a DVC sub, it TOTALLY depends on what amp you are using to power it. For the most flexibility, I would get a dual 2 ohm sub, that way you have the option to wire it as 4 ohm x 1, 2 ohm x 2, or 1 ohm x 1. Since any decent amp should be able to drive 2 x 2 ohm, and better ones 1 x 1 ohm.
Someone may have better insight, but that's just how i interpret it.
04-27-2006, 02:17 PM
Don't forget on the sub...the less resistance you have the sloppier the bass is going to sound. The bass WILL be louder, but if your looking for cleaner bass...stick around 4 ohms. Some of the old school rockford amps will even handle an 8 ohm load for a sub. Again it won't be as loud, but it'll be super clean sounding.
You ever take it off of any sweet jumps?
04-27-2006, 04:18 PM
So you're running fronts, rears and a sub, right? Seems to match up pretty well to me with the 3 outs from the deck :P - Front/Rear/Non-f usually... just run 2 RCA runs from the HU to the 4 channel (Front/Rear out to Front/Rear in on the amp) then 1 RCA run from the Non-f out on the HU to the sub amp.
As far as your tweets, unless you're biamping or running an active soundstage, they should wire straight out of the passive crossover.
As far as the sub wiring - all depends on the RMS rating of the sub and the amp - figure out what your VC config is, what the RMS rating is, and what your amp will do at different loads, then wire appropriately - also if you haven't bought a sub or amp yet or only have one or the other, match them up when buying.
Cheers,
~vR
04-27-2006, 06:15 PM
AutoCross Alero
i sent you a pm formula.
04-28-2006, 07:37 AM
thanks everyone, i'm going to add a little more here and see what i get.
i completely forgot about passive crossovers with component systems, so yea. basically i want to power 4 speakers 150w each at 2 ohms, and two subs, DVC, at 200w per sub at either 2 or 4 ohms, i listen to mostly rock and would prefer 4 ohms, but i dont want to spend an arm and a leg, so i may have to step down to 2ohms to get something that pounds and is affordable.
i hope this clears some things up, i realize now that i dont have ot worry about the stock amp, i can pull it out, because all of my sound will come from pre-outs and into 2 or 3 amps.
Cliff Notes:
i need a 4ch capable of 150w (X4) at 2 ohms (4 ohms if thats too expensive) and the best setup (as far as running the coils in series, parallel, etc) to get the most power out of 2 eclipse dvc subs and an eclipse amp that puts out 200wrms at 2 ohms
04-28-2006, 09:14 AM
how would i wire that amp to connect 6 speakers total? i dont think i understand.
04-28-2006, 11:40 AM
Ah hell, I read "& 320x2" as "+ 320x2" - the 320x2 is a bridged output, my mistake. I was thinking along the lines of the 5150XXK, which has a sub out also. The 4150 will still run your cabin speakers like a gem though - and I did see a 5150 go for around $500 not too long ago.
~vR
04-28-2006, 04:30 PM
that picture helps and all, but it just shows a single sub with a single voice coil... i've hooked all those up no problem, and when you first showed me the 4150, i saw the 5150 on the site, but that's pretty underpowered for what i want, and i dont think it'll work well with the two dvc subs.
04-28-2006, 04:32 PM
i just need 1 4 channel for the fronts, and a guide about how to hook up the 2ch i have with the dual voice coils and having it all run at 2 ohms. like the coils in series, but the subs in parallel. i think.
04-28-2006, 04:35 PM
04-28-2006, 04:39 PM
thanks man, it helps a lot to see pictures :P now i've got a better idea of how it works.
would you recommend a distro block or something to "split" the ground and the power in this picture? this is the setup i need.
in that picture would that amp be running bridged? it says wired like that that 2 4ohm subs would run at 4ohms, i thought that it would bring it down to 2 ohms?
04-28-2006, 04:43 PM
Those are speaker wires you see, not power and ground. You just hook the wires up with caps or solder or however you want to do it when running series/parallel.
With two amps though, you will want a distro block.
Actually just got finished taking some pictures - here's my distro:
04-28-2006, 04:51 PM
well i know they're speaker wires, but ones hot and one is still ground, i meant, where the red "speaker wire" splits, how do you go about that?
04-28-2006, 04:55 PM
i think i understand now, basicall the amps they show are mono's.
so with 4ohm dvc in parallel, one sub on one channel, at 2ohms, and the other sub on another channel at 2ohms, (the ohms stay at 2 on both channels because the channels are seperate?) because it's not possible to wire both subs to a single channel at something other than 1 or 4 ohms.
is this right?
04-28-2006, 05:00 PM
If you're talking about a 2 channel then yes, wiring single 4ohm DVC drivers each in parallel and connected to discrete channels on the amp will put the amp at a 2ohm load per channel
With 2 4ohm DVC drivers, you can wire to 4 or 1 ohm when powering with a monoblock.
is this right?
04-28-2006, 05:02 PM
k, cool, i get it now. so i need a 2ch amp with 200rms at 2 ohms on each channel.
04-28-2006, 05:06 PM
