Old 04-28-2006, 11:54 PM   #1
TwistedDreams
VIP
TwistedDreams's Avatar
TwistedDreams is an unknown quantity at this point
Send a message via AIM to TwistedDreams
how are you suppose to take the plastic part off the rear deck that goes over the 6x9 speaker because I got some others that came with the speakers and I want to use them, do you have to cut them off or is there an easier way?
Gunnery Sergeant Hartman: "I'm going to rip your balls off, so you cannot contaminate the rest of the world."
TwistedDreams is offline   Reply With Quote
Old 04-29-2006, 03:21 AM   #2
elitecloud
elitecloud is an unknown quantity at this point
Send a message via AIM to elitecloud
if it's a 4 door, i know you have to put the back seats down, take the Left and Right Upper molding's off, take the black modling where the seats latch thru off, and life and pull the cover off
2006 Toyota X-Runner
elitecloud is offline   Reply With Quote
Old 04-29-2006, 11:00 AM   #3
Chucklez05
I think he's talking about the actualy plastic part thats attached the whole peice, am I right?
If thats what your talking about then their should be what look like plastic rivits going around the edge of the opeing, if you drill out the head of it and it should come off. Thats what i did on mine.
Old 04-29-2006, 11:08 AM   #4
TwistedDreams
VIP
ok thanks cuz I got some 6x9's that dont fit like the stock ones so I have to used the covers that came with the speakers to screw them in so the speakers dont move.
Old 04-29-2006, 11:14 AM   #5
Chucklez05
Ahh I C, yea just drill out the rivot heads and they should pop off.
Old 04-29-2006, 11:18 AM   #6
TwistedDreams
VIP
one more question
I took seats down got plastic piece off held on by 4 plastic screws and now im ready to take rear deck off, its not coming off and there is nothing else I can take off to ease it out (side cushions on seats....etc) am I missing sometihng?
Old 04-29-2006, 11:20 AM   #7
acold7dusta
just out of curiosity, what kind of 6x9s did you get? i have kenwoods and they fit in there fine with no modification (it was tough pushin them in tho)
Old 04-29-2006, 11:23 AM   #8
acold7dusta
right behind the rear window there are molding strips about 4" wide and if they touch ur rear deck and ceiling, you found it. make sure you pull it straight out, and not curving one side to the front or back because you will break the clips
kev
Old 04-29-2006, 11:41 AM   #9
Chucklez05
also whenever i need to remove my rear deck i have to take off the entire back area pull out the backrest, remove both the interiour pieces off of both sides, then the deck area. but i have a two door though.
Old 04-29-2006, 08:03 PM   #10
TwistedDreams
VIP
Pioneer 6x9 Speaker, TS-G970M
Old 04-29-2006, 11:28 PM   #11
2fst4u
[boosted 2.4L]
2fst4u's Avatar
you may have to bend the deck in the middle to get it out. with it being carpeted, you shouldn't notice after its back in.
also, i have those same speakers (in a 3 way), and they fit fine. not sure where the problem is.
Old 04-29-2006, 11:49 PM   #12
TwistedDreams
VIP
what I mean is: "It doesnt match the shape exactly like the stock ones the only way to put them in with out them moving around and vibrating against the metal while driving is to use the guards it came with so you can screw the speaker to it so it isnt resting on the metal. "
Old 04-30-2006, 09:33 AM   #13
acold7dusta
why cant you snap it into the black plastic shroud like the stock ones went into?
Old 04-30-2006, 09:43 AM   #14
TwistedDreams
VIP
it doesnt have clips like the stock ones do
Old 04-30-2006, 10:04 AM   #15
acold7dusta
OOOO i see what your trying to do...you didnt remove the stock speaker from the plastic shroud...the stock speaker has 4 hook like things holding the speaker in on the top. unlatch them and pull the stock speaker out. when you put the pioneer one in its gonna be tougher to get in due to its a little larger than stock, but it will fit in with little to no modification (i think i had to break the black tabs that were sticking up and interfering at one of the ends)but anyways try that and tell us how it went
Old 04-30-2006, 11:01 AM   #16
TwistedDreams
VIP
I appreciate the help one of them worked but I had already throw one of them away and it had that plastic piece on there so I only have one. but thanks anyway.
Old 04-30-2006, 07:05 PM   #17
acold7dusta
ooo boy...if its long gone, i would be trying to look for one in the junk yard or something cuz ur gonna need that
Old 04-30-2006, 09:36 PM   #18
2fst4u
[boosted 2.4L]
2fst4u's Avatar
yeah, you're better off with those brackets.
