Old 05-02-2006, 12:23 PM   #1
violentrapture
violentrapture is an unknown quantity at this point
Send a message via Yahoo to violentrapture
Found a HO exhaust manifold - will this go on the 2.4L, and is there any gain to be had from doing it if so?
Thanks,
Collin
violentrapture is offline   Reply With Quote
Old 05-02-2006, 01:04 PM   #2
You might have a problem routing that around the steering rack on the car. I know most of the cars with the Quad4 HO (except the rare Cutlass Supremes) have the rack mounted on the firewall, where the Alero's is mounted to the cradle. It's definitely a tight fit to interchange the V6 manifolds between the two platforms (been there done that). I don't know about the 4-cylinders, It could be a potential problem. Also, if your car has EGR, this manifold will not support it. (that is, if it will even bolt up?)
Old 05-02-2006, 05:17 PM   #3
violentrapture
What about this - does it actually help like it says?
Unorthodox Ultra S Crank Pulley
http://tinyurl.com/o28qe
Old 05-03-2006, 12:33 AM   #4
Oldsman
Owner
Oldsman's Avatar
2.3 ho exhaust manfold will not work. wrong bolt pattern and ports are way bigger
Beware of the BackStabber
