Go to your local automotives store, the kit is any where from free(five finger discount) to 20 bucks
Kit includes
Cleaner
Oil
Instructions
Steps : if you don't want to follow thier instructions :alcoholic: <-- or your and dont have time to read fine print
1 - Remove filter (jack car up for cai's etc.)
2 - Tap excess dirt from the filter with hand (small child can be used as a tool)
3 - spray the outside of the filter (part that has direct contact with outside air) with cleaner, don't soak it but you want it to clean
4 - let sit for 10 minutes in shade to start cleaning *DO NOT LET CLEANER DRY INTO FILTER*
5 - rinse filter from the inside out (water into hole) and let gravity carry the debris/dirt out, make sure you get all cleaner out
6 - let it dry (instructions say naturlly) this is aleromod, we mod aleros that's not natural F natural
7 - after drying - apply oil lightly to blades evenly (oiling is complete when both sides of the filter show a pink color AFTER 20 minutes of sitting to let oil seep into the filter
***if after 20 minutes of absorbing oil is dripping / leaking START OVER***
((Several Light coats are better than 2 heavy coats))
8- assuming 20 + minutes have passed and filter is pink and oiled resistall
will post pictures once filter is completly dry ;-)
