Old 05-16-2006, 06:22 PM   #1
littlebandito
Every now and then all my speakers cut out and I only hear music through my subs. Im guessing theres something loose, but I dont know wether its with the speakers or the head unit.
Old 05-16-2006, 09:00 PM   #2
mikegett
mikegett's Avatar
Do you have a external amp (or monsoon amp) on the speakers. If so, you need to check its harness. Either the turn on signal, 12 volt or ground has a bad connection. If you have the speakers running off the HU, then it most likely has a internal problem with the amp.
