05-19-2006, 11:08 PM
ok i have a 99 gls and it isnt the monsoon but it does have a factory amp in the back,,how hard will it be to install an aftermarket cd player?
Clarion VRX775VD
Eclipse 21010 Indash EQ
Zapco I 6.2 comps
Memphis M-Class 6x9's
Treo SSi 12.22 x 2
JL Audio A1800 on subs
JL Audio 300/4v2 on comps
Optima Yellowtop and Big 3 upgrade
[boosted 2.4L]
easy. buy a dash kit and a harness. very easy.
05-19-2006, 11:09 PM
so that factory amp wont interfere with the new head unit?
Clarion VRX775VD
Zapco I 6.2 comps
Treo SSi 12.22 x 2
05-19-2006, 11:11 PM
Shouldn't. I've got the Monsoon amp and just had to wire the amp turn on wire to turn on the amp  .
??,??? km
??,??? miles
05-20-2006, 12:58 PM
Ok quick queston and im sure its a rather dumb one. So some of the aleros came with a amp already installed? and if so how do you know if it came in your car, find it, and hook it up to work with the new speakers/headunit?
Sorry if that was dumb but ive never hear of any of this.
05-20-2006, 01:18 PM
[boosted 2.4L]
search it. it's called the monsoon amp. there's a how-to somewhere.
05-20-2006, 01:19 PM
Let's Play Army!
the ones with a stock amp have it in the trunk. pop the lid on the trunk and pull open the carpet behind the driver's side tail lights in the trunk. If you got it, you'll know for sure. if there's nothing there, just flat partially-painted metal, then you don't got it.
Originally Posted by black
05-20-2006, 02:11 PM
k thanks
05-20-2006, 02:45 PM
you dont actually have to wire the speakers to use the amp. just make sure you wire the amp turn power wire with aftermarket harness to the stock harness
joelsoundxtreme: u faggot
05-20-2006, 03:08 PM
and what color wire would that be,,lol
Clarion VRX775VD
Zapco I 6.2 comps
Treo SSi 12.22 x 2
05-22-2006, 07:21 PM
Just do a search for the monsoon wire code. There have been quite a few posts leaving it. I believe it was 03blackgx (or something like that). All aleros with a OEM amp use the monsoon. They all have the same pin out just don't state monsoon across the amp. My 03 is just called a premium system with a non marked amp. it is identical to the monsoon I have seen.
