05-22-2006, 09:25 PM
For alarms:
[attachmentid=10520]
[attachmentid=10521]
05-22-2006, 09:28 PM
Radio:
[attachmentid=10522]
05-22-2006, 09:34 PM
Another radio:
[attachmentid=10523]
05-22-2006, 09:45 PM
Owner
Joel i am going to sticky this.
Beware of the BackStabber
05-22-2006, 10:12 PM
thats why i posted it so it could get stickied :P
05-23-2006, 01:53 AM
Easier dome light hook up:
[attachmentid=10526]
the black/red wire will be positive if your alarm trigger is negative, or negative if the trigger is positive.
05-27-2006, 12:55 PM
for the parking lights i used the dark brown wire under the column cover on the connector on the light switch. it takes a positive pulse, i think all alarms/kes come with a fused positive parking light wire so you should be able to tap right into it.
05-27-2006, 01:31 PM
trunk release i used the black/white wire coming from the drivers side door at the kick panel. it needs a negative pulse or a grounded relay.
05-30-2006, 01:36 PM
Do you happen to know what color the O2 wire is, that is behind the engine. For attaching the A/F Ratio Gauge
05-30-2006, 05:06 PM
i think it's purple, i just tapped in at the sensor.
05-30-2006, 05:09 PM
i've been hunting for a wire that will turn on the dome light, when the door opens, and off, after several seconds...
i've found one that turns on, when the door opens, but stays on. Another that turns on, when the door closes... (both in the purple bundle under the driver's side floor panel)
any ideas?
05-30-2006, 05:51 PM
you could use the door sensors in one of the doors.
05-30-2006, 05:58 PM
or u could use a decent sized capacitor. it'd give that "fade" effect. or u can use a 555 timer i think.
05-30-2006, 09:08 PM
i tried testing the door sensors...
maybe i was testing it wrong, but it didn't seem to have what i needed, on one wire. i believe its a combination of wires, running to something...
05-30-2006, 09:27 PM
you are correct about the sensor. you need to touch the 2 wires together. use a relay to do that
11-07-2007, 02:00 PM
We need to update this sticky
12-14-2007, 11:29 AM
x2 i'm installing mine this weekend
this site looks good: http://64.85.6.118/diagrams/diagrams.asp
12-15-2007, 02:03 PM
lol attachments disappeared
06-06-2010, 02:24 PM
Thank you very much.
"If the author of the Declaration of Independence were to utter such a sentiment today, the Post Office Department could exclude him from the mail, grand juries could indict him for sedition and criminal syndicalism, legislative committees could seize his private papers ... and United States Senators would be clamoring for his deportation that he... should be sent back to live with the rest of the terrorists." - Frank I. Cobb
