Old 06-05-2006, 11:24 PM   #1
Orion
I have filled my tires all to 30 PSI, and I have tried holding the reset button in ACC and in the ON postion. Regardless, it doesnt change for flicker or anything. How can i get it to go off. I don't believe my tires where low, i mean I did replace my battery. So would that affect where the PCM thought my tire pressure should be?
Old 06-06-2006, 12:28 AM   #2
strtrydr
strtrydr's Avatar
Okay...Turn key to ON...Remove Driver Side Fuse Cover...Hold RESET for 5 sec...Push RESET 2 times (Tire Pressure Light will begin flashing)...Push and Hold till chime sounds.
Old 06-06-2006, 01:42 PM   #3
Orion
Thank you
Old 06-06-2006, 10:27 PM   #4
strtrydr
strtrydr's Avatar
^No Problem :P
Old 06-06-2006, 10:27 PM   #5
Youngblood77
Youngblood77's Avatar
If it comes back in under say, a week or 2, then have your ride scanned for the "bad hub scenario". The vehicle speed sensor that goes bad not only is used to determine whether or not the vehicle's tires are spinning, ( the PCM comparing readings from multiple sensors ) but it also is used to determine if your tire is low. One sensor is reading revolutions in X amount of time, and the PCM is comparing it to the other wheel's sensor. So, using this sensor, and being programed to KNOW the diameter of your tire; it gets a reading that's faster than the opposite wheels from it, then it'll give you a Low Tire Pressure light.
Sorry my explaination was so long-winded, but I figured you'd want a reason for my suggestion. Hope this helps.
Old 06-06-2006, 10:46 PM   #6
Orion
Thanks Man
Old 06-06-2006, 11:40 PM   #7
ryanthefizz
ryanthefizz's Avatar
ryanthefizz is an unknown quantity at this point
with that in mind the light usually goes on when its in upper 20's for pressure so if you have a lot of fluxuation in weather... really cold at night and hot in the day its common for the tire to drop at night, trip the light in the morning and repeat, happened to me most of last month, just fill them to 32-35 if it keeps happening and see if that helps before u spend $$
ryanthefizz is offline   Reply With Quote
Old 06-07-2006, 07:35 AM   #8
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
the light comes on when at least one wheel spins at a rate of "12rpm's slower than the other wheels at 60mph". So this can happen from hitting a pothole on the highway.
Old 06-07-2006, 08:53 AM   #9
Orion
I reset it yesterday and it went off. Then I was driving today and i heard a chime, and my traction off light came on, on the dash. Hitting the button did nothing.
Old 06-08-2006, 08:48 AM   #10
steve-o
Canadian... Eh?
steve-o's Avatar
steve-o is an unknown quantity at this point
Send a message via MSN to steve-o
that happened to me a few times, and the car feels right sluggish switching gears as well. But if you shut the car off for a bit, it'll fix itself. Just another alero "extra" that comes with the car.
steve-o is offline   Reply With Quote
Old 06-08-2006, 12:12 PM   #11
jackal2000
jackal2000's Avatar
hmmmm could be your hub as mentioned earlier.
Old 06-08-2006, 12:21 PM   #12
Orion
Well this has been happening for alittle while. When I hit the breaks sometimes it sounds like a crunch or creaking noise, any thoughts?
Old 06-08-2006, 07:53 PM   #13
Youngblood77
hub. That creaking/crunching noise sounds like a bearing going bad imho.
Old 06-08-2006, 11:06 PM   #14
Orion
So its a hub bearing or the hub?
Old 06-10-2006, 06:31 PM   #15
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
by reading everything im almost sure it is..... i had to get mine changed and my traction control light was acting up....
battistoni21 is offline   Reply With Quote
Old 06-10-2006, 08:18 PM   #16
Youngblood77
That sound imho is the sound of the bearing itself failing, but the entire hub needs to be replaced, as I'm 90% sure the hub bearings aren't sold individually.
Old 06-10-2006, 11:34 PM   #17
strtrydr
strtrydr's Avatar
^ You are correct the hub bearing is actually part of the hub and you cannot get the bearing seperatly...gotta replace the whole hub
Old 06-10-2006, 11:39 PM   #18
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
All my air pressure monitors are fried lol I hooked it up to the GM scantool and it said they all were blowed. The dealership said 300 for each wheel, so forget that poop lol, In just gonna take off the monitors and remove the light in the dash :alcoholic:
Old 06-12-2006, 12:49 PM   #19
FartCannonAlero
helped me out with the "tire pressure" and "change oil" schweeet
Old 06-12-2006, 09:37 PM   #20
MixtapeMessiah
That method dont work with me car anymore. My ECM is blown and so is my engine : /
