Old 06-10-2006, 02:15 PM   #1
Oldszilla
I'm new here so i dunno if its been asked b4. How do i get out the trim around the radio and around the shifter so i can clean/paint it up?
Old 06-10-2006, 04:56 PM   #2
the shifter has to be removed. (small staple on the inside front)
then pry up on the little edge before the cubby. that should pull the shift trim up.
then grab the bottom edge of the HVAC console, and pull that forward. (toward you)
made sure you get all the wires detached safely.
also, try using the "search" key at the top, or surf through the How To section...
Good luck, and post pics when done.
