Old 06-13-2006, 10:21 PM   #1
rogan19
how do i install a air/fuel guage on my 2.4L ? do i just run a new oxygen sensor and then run the wires to the guage how to i got about wiring it?
Old 06-13-2006, 11:14 PM   #2
Purple wire comming from the 02 sensor. Tap into that
Old 06-13-2006, 11:14 PM   #3
2fst4u
[boosted 2.4L]
2fst4u's Avatar
there is a purple wire in the loom that comes off of your upstream O2 sensor. just tap into that for your signal.
Old 06-14-2006, 01:28 AM   #4
hmm.....if you just want some pretty blinky lights that look cool, then tap it into your existing O2 sensor wire.
If you want an A/F that actually works, then you need to get a wideband O2 sensor (like Bosch for example) from this link Innovate Motor Sports and do it right.
Old 06-14-2006, 11:47 AM   #5
rogan19
wht do you mean everyone says to tap into the purple wire. will it not give me an acurate reading?
Old 06-14-2006, 12:19 PM   #6
2fst4u
[boosted 2.4L]
2fst4u's Avatar
no, you will be doing the right thing with the purple wire, he's just recommending a wideband air/fuel gauge to tune off of. unless you are going with forced induction or something, the pretty blinking gauge works fine.
Old 06-18-2006, 05:37 PM   #7
rogan19
where is the O2 sensor?
Old 06-18-2006, 10:26 PM   #8
2fst4u
[boosted 2.4L]
2fst4u's Avatar
what engine do you have? it's going to be located on your exhaust manifold collector. it is two wires connected to what looks almost like a spark plug. follow the wires up to the loom, and then pull the loom back until you find the purple wire.
