Old 03-02-2004, 09:55 PM   #1
aleropimp1
OK i have an intake on my car and i got a new muff and for the next thing i wanted to go with new exhuast headers. i have a 2.4l manual 2001 alero and i wanted to know what a good header was that will fit and be easy to instal, also is cheap becouse i am cheap i don;t want to spend to much i am gready. o ya and will it change the sound of my car and what nots.
Old 03-02-2004, 10:10 PM   #2
Oldsman
Owner
Oldsman's Avatar
cheap is pacesetter header. but you looking at around $200 for install of header.
Beware of the BackStabber
Old 03-02-2004, 11:07 PM   #3
aleropimp1
really you don;t think i could do it myself i am kinda handy i put my intake in my car in about 10 mins
Old 03-02-2004, 11:13 PM   #4
Oldsman
Owner
Oldsman's Avatar
you need acustom downpipe. you need to have the upstream o2 snsor either mounted on the oppisite side(passenger side) or put it in the down pipe.
Old 03-03-2004, 01:08 AM   #5
Fast Eddie
I recomend on the other side, for the O2 sensor. Oldsman are you having any problems with that setup? the down pipe idea is giving me a nightmares, I re-doing the whole thing when I a job.
You could do it yourself if you have the following:
1. a lift
2. a MIG welder w/ SS wire.
3. a pipe bender
4. a pipe expander/reducer
and a few other things
What I plan on running is the OBX header, unless I can aford Stan's, pacesetter is poop, the ID flex pipe, and my catco cat. all 2.5" from the down pipe to the 2.25 mandrel bent borla. Oh yeah that will give me a full stainless setup (if I use the OBX) from the head to the tips
Anyway you slice it your looking at about 350-400 installed for most headers.
I'm on a boat.....
Old 03-03-2004, 05:49 PM   #6
Oldsman
Owner
Oldsman's Avatar
nosweat, did the ceramic pacesetter header. they put his o2 on the passenger side of the collector. after they finially got the right o2 sensor it started working good. his install cost him a little over $200.
Old 03-17-2004, 02:35 PM   #7
97cavie24ls
hello , i work at pacesetter and we just got done fitting the grand am
and we are going to have a new part # header for the 99-02 2.4 N-bodies
ill let you guys know as soon as i get the part # for the header
also we are doing a single 2.25 exhaust with a cross flow muffler with dual outs with dual tips on each side
just wanted to let you guys know
Old 03-17-2004, 02:59 PM   #8
Molson
Molson's Avatar
how much is the pacesetter header?
Old 03-17-2004, 03:19 PM   #9
Fast Eddie
just a word of warning, after doing serious reading on EFI, DO NOT mount the O2 sensor in the downpipe. This throws off the reading and will generate codes. According to everything I have read, including GM's manuals, the upstream sensor needs to be as close to exhaust ports as practical. In other words in the collector.
As for pacesetter cost. the 2.4 black steel is ~$150USD and ceramic ~$250USD from highrevmotorsports.com
I'm on a boat.....
