07-12-2006, 02:24 PM
Turn Signals
Okay My turn signals f*ck up. They only go on some of the time. Then most of the time its nothing, it sometimes turns back on when I hit the hazards but most of the time those dont work either. I looked at the fuses and they are fine. When I push the stick forward to lock the brights, that doesnt work either. wtf can this be! I am getting really sick of it.
Post up any ideas...
2004 40th aniv. mustang
2006 kawasaki ninja
07-12-2006, 02:30 PM
hazard switch recall, take 'er in and see if you're on the list, if not just buy a new hazard switch and put it in...problem solved...well 9 times out of 10 that is
07-12-2006, 03:24 PM
^ what brad said!
07-12-2006, 04:50 PM
Hazzard switch recall huh?
hazzard switch recall huh? hmm so I will take it to carmax where I got it I guess. I dont think I am underwarrenty anymore though. We will see
2006 kawasaki ninja
07-12-2006, 05:03 PM
Let's Play Army!
recalls have nothing to do with warranties. recalls are issued by manufacturers so that you can get a free repair. Also, this technically wasn't a recall, so don't expect it to get done by the dealer. however, it is a cheap fix to do it yourself.
Originally Posted by black
07-12-2006, 05:30 PM
Well would I still go to carmax to get it fixed? Or shoudl I just buy the part and do it myself. (which I dont have a clue how to do, maybe if there was some directions or somethin)
2006 kawasaki ninja
07-12-2006, 06:15 PM
Let's Play Army!
take it there first. if they can do it, sweet deal. if not, it's really simple. the only tool you need is a flat head screwdriver.
all you do is pry out the button trim and the button. carefully unclip the button from it's bundle of wires (haven't looked in a while, it's a small bundle though) and replace the button and put it back together. no unscrewing, no ungluing. it's a sub-2-minute job.
07-12-2006, 10:48 PM
Sweetass
..................................(msg was too short)........................................sadl fhasodifwoiefal;skdfjwoeifjalkdfsdfsdfsee;lkasjdfy oulaksdfinlaksdjhelll;aksjdf -figure it out
2006 kawasaki ninja
07-13-2006, 11:04 AM
Hazards...
Had the same problem the hazard switch messes with the signals.
07-13-2006, 03:30 PM
thats stupid
2006 kawasaki ninja
07-31-2006, 04:11 PM
Ok, I am having the same problem. I called dealership and they said that the hazard switch has been replaced. Can it still be replace by recall or am I SOL. I am assume if it can not be fixed that I can easily replace the switch.
07-31-2006, 04:12 PM
well maybe they f'd it up the first time
09-22-2006, 12:51 PM
Well, I have to give you an update.... it pays to blow off steam to GM Canada. I decided to use the GM website and a service rep came back explaining that it should be taken care of. Today, I went in the dealership, talked to the service manager and he still stated that it will be not fix. I said that GM Canada made it clear that it will be fix. Well it is fix as a recall so no charge. Seems the dealership does not have the last call....
If you are not happy with your dealership answer, go back to GM...
09-23-2006, 03:01 AM
The dealership practically never has the last call. The dealership is merely like a franchise. If GM gets enough complaints about a particular dealer they will pull their line from that dealer. In a way it's worth it for GM to fix your small problem just so that you consider to buy another GM vehicle for your next purchase.
09-23-2006, 10:54 AM
still havent gotten a switch yet.
2006 kawasaki ninja
