Old 07-23-2006, 12:10 AM   #1
burg03
Funny Temp Gauge
Do anyone has a temp gauge that looks like this when the engine is warm and the a/c is off?
Old 07-23-2006, 12:37 AM   #2
shackney
shackney's Avatar
shackney is an unknown quantity at this point
Send a message via AIM to shackney
ya thats how mine looks
shackney is offline   Reply With Quote
Old 07-23-2006, 01:57 AM   #3
mine stays about that same distance BELOW the half mark, but by design. I put in a 180 Tstat and adjusted high speed fan turn on to a lower temperature so that temps stay a little over 180. Most efficient operating temperatures are between 180-220 degrees. I also set the fans to stay on up to 2 minutes after engine shutoff.
Old 07-23-2006, 09:33 AM   #4
burg03
How? Please help a brotha out. I have the 180 t-stat(not installed) but not the fan adjustment.
Old 07-23-2006, 12:42 PM   #5
megabyte
megabyte's Avatar
megabyte is an unknown quantity at this point
That's exactly how mine looks also.
megabyte is offline   Reply With Quote
Old 07-23-2006, 02:03 PM   #6
easy. Drop $400 for a DHP PowrTuner and you'd be amazed at the things you can do with it
Old 07-23-2006, 02:54 PM   #7
Flush the coolant system. Make sure you go the postive way, going again the flow will cause the head gaskets to break
Old 07-23-2006, 03:31 PM   #8
exnine@gmail.com
exnine@gmail.com's Avatar
exnine@gmail.com is an unknown quantity at this point
Send a message via AIM to exnine@gmail.com
Mine does that too, It freaks me out too.
Have you guys heard of "Water Wetter?" A friend of mine recommended it, and said it would help to keep the temp down.
Welcome to my sig.
exnine@gmail.com is offline   Reply With Quote
Old 07-23-2006, 03:46 PM   #9
robz02alero
robz02alero's Avatar
robz02alero is an unknown quantity at this point
Send a message via Yahoo to robz02alero
Mine NEVER does that. In fact mine barely ever goes above the halfway mark except maybe in traffic. I'm glad too.
owner/operator of : The Pinnacle of Clean Auto Detailing Service www.pinnacleofclean.blogspot.com
Supporter of Aleromod.com
OIF VETERAN X3
COMING HOME SOON
robz02alero is offline   Reply With Quote
Old 07-23-2006, 04:17 PM   #10
14alero
14alero's Avatar
14alero is an unknown quantity at this point
Send a message via Yahoo to 14alero
Mine never goes above a quater i have the Intense pcm and 180 stat
14alero is offline   Reply With Quote
Old 07-23-2006, 07:49 PM   #11
if yours doesn't go above a quarter, then I'd have that looked at too. it needs to warm up more than that to get to efficient operating temperature. Colder is not always better. Cold temp operation creates more wear on rings, bearings and other moving parts.
Old 07-23-2006, 09:36 PM   #12
Mine usually hangs out between 1/4 and 1/2
Old 07-23-2006, 11:22 PM   #13
shackney
shackney's Avatar
mines at half lil above and every once in awhile it will get up to 3/4 i have no temp mods
Old 07-23-2006, 11:31 PM   #14
yeah depending upon the day and operating conditions, mine will hang out there as well...i got a tip from a mechanic one day as I was about to blow up the engine in my work van...to turn the heat on full blast and pull some of the heat out of there and to hit the open road as soon as possible and let some cooler air flow in
Old 07-24-2006, 08:25 AM   #15
here ya go, i took this on my way to work this morning...while sitting in traffic, no a/c...nothing...
Old 07-24-2006, 12:26 PM   #16
acold7dusta
mine only goes over when the A/C is on
Old 07-24-2006, 03:07 PM   #17
burg03
Well I guess I have my work cut out. $400 for DHP tunner huh..........hmmmmmmmmm sounds good. Since I am not the only one with this problem, maybe i can wait for the cat back and headers first.
Old 07-24-2006, 03:09 PM   #18
its not a problem...its normal operating temperature...dont sweat it and I thought they were selling the dhp's for 99 now?
Old 07-24-2006, 03:10 PM   #19
Orion
Yes they are i got one from PFYC, from DHP for my 99
Old 07-24-2006, 04:26 PM   #20
strtrydr
strtrydr's Avatar
Double0...I think burg was talking about the DHP PowrTuner
