Old 07-26-2006, 11:54 PM   #1
trumpetplayer91372
trumpetplayer91372's Avatar
trumpetplayer91372 is an unknown quantity at this point
Send a message via MSN to trumpetplayer91372
Rim question
I am looking around at some rims and i found one that i like, but it doesnt give any specs to bolt pattern etc. just that its 18 x 7.5. A few other sites kind of list it, but i still dont see enough info to know if they would work, what can i do to find out?
trumpetplayer91372 is offline   Reply With Quote
Old 07-27-2006, 12:52 AM   #2
derek_ski99
derek_ski99's Avatar
derek_ski99 is an unknown quantity at this point
Send a message via AIM to derek_ski99 Send a message via Yahoo to derek_ski99
how bout call the website or manufacturer? that'd be my first step.
2nd step would be to post pictures so we can give you our opinions before you buy some hideous wheels like many others have done
Brent: and in the end...... cherrington is still a cum dumpster whose closest contact with HOT women is through a car internet forum ........... so as long as we can agree on that........ we can all go back to being friends.
Being Brents friend is teh hotness
derek_ski99 is offline   Reply With Quote
Old 07-27-2006, 01:09 AM   #3
trumpetplayer91372
Heres the 2nd step.
Old 07-27-2006, 12:00 PM   #4
Doomgiver
I like them minus the rivits... otherwise they're pretty clean rims they'd look good on an alero
Old 07-27-2006, 12:26 PM   #5
derek_ski99
they're a bit too flashy for my taste..but i prefer very simple and clean wheels. the almighty question is do you like them? and if the answer is yes then go for it
Old 07-27-2006, 01:26 PM   #6
trumpetplayer91372
I know the bolt pattern is 5 x 115, but what is the offset and can someone briefly explain what it means?
Old 07-27-2006, 07:15 PM   #7
derek_ski99
offset needs to be between 35 and 42 if im not mistaken and once again we cant answer specs on your wheels considering we are not the manufacturer. i'd say if its a 7.5" wide rim and has a bolt pattern of 5 x 115 you should find that they have the correct offset.
Old 07-27-2006, 11:36 PM   #8
trumpetplayer91372
Maybe i worded that wrong. I don't know what the bolt pattern is for those wheels so I will still need to find out. When I said I knew the bolt pattern was 5 x 115 above, i was refering to the standard bolt pattern for our cars, and I didn't know what our offset was or what it means. So can you kind of explain what the offset is offsetting just so I can better understand what I am looking for?
Old 07-28-2006, 12:46 AM   #9
alerocar01
alerocar01's Avatar
alerocar01 is an unknown quantity at this point
i think the offset has to do with how far the hub pattern is from the center of the wheel. if it is towards the front then there is negative offset and if it is toward the bad then it is positive. not sure tho.
alerocar01 is offline   Reply With Quote
Old 07-28-2006, 01:37 AM   #10
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
to learn about what all those numbers mean:
http://www.rsracing.com/tech-wheel.html
Old 07-28-2006, 04:12 PM   #11
trumpetplayer91372
Can i get a few opinions of what you guys think of those rims? I know some of you seem to stay away from chrome and would rather have a racing rim or simple 5 spoke, but I like chrome and was just wondering a few honest opinions.
Old 07-28-2006, 04:15 PM   #12
SweetNLow
SweetNLow's Avatar
thye look abit bulkey. but i prefer chrome over anyother type of rim.
oh and rivots suck........ impossible to clean so you might want to consider looking around for some other options
joelsoundxtreme: u faggot
Old 07-28-2006, 04:19 PM   #13
jackal2000
jackal2000's Avatar
ya i can vouch that rivets suck. unless its actually a 3 piece rim, which it is not.
Old 07-31-2006, 05:53 PM   #14
we can also fit a 5x114.3mm=5x4.5" and we can fit offset outside the taboo 35-42 range but people are too narrow minded to realize that......if you want some sweet rims for cheap check out GAGT.com
http://www.grandamgt.com/forum/showthread.php?t=62792
those are probably your style, there are also some 077s on there too.....
