I kind of doubt that you overpowered your speakers. The lower the sound waves, the more wattage that is needed to reproduce it. With your bass being blocked, your amp is probably only reproducing 50 watts RMS. Even with your gains set to maximum, and your volume at peak, it will seldomly use much wattage. Most likely, the tweeter has blown from poor quality controls. If not, it could be a poor termination at the amp or rca. Simply swap the rca inputs and see if it travels to the other speaker. If so, your terminations are the cause.
The infinity comps are pretty nice. Just go with a 51/4. Very few 6.5 comps will fit in the doors. Comps tend to measure the woofer size while lower end speakers measure the entire woofer and frame. My eclipse and JL comps were nearly 7 3/4 inches at the basket.
