Old 08-04-2006, 02:40 PM   #1
olds03alero
olds03alero's Avatar
olds03alero is on a distinguished road
Send a message via AIM to olds03alero
projectors are in
i just got done, took me about 4 hours to do it. i'm really liking how they turned out, just need HID next.
http://www.cardomain.com/ride/2290729
olds03alero is offline   Reply With Quote
Old 08-04-2006, 02:45 PM   #2
pretty sweet man...please tell me you did a how-to while you were doing this
Old 08-04-2006, 02:46 PM   #3
eag182
the projectors look like a moon in the night sky
Old 08-04-2006, 02:46 PM   #4
olds03alero
not exactly, but i'll write something up with some pics later today to tomorow. its pretty easy you just have to take your time.
Old 08-04-2006, 02:50 PM   #5
jackal2000
jackal2000's Avatar
look coolio
Old 08-04-2006, 04:06 PM   #6
olds03alero
I Haven't used these at night yeat, so i may need to modify a high beam bulb to make them bright enough. not enough cash for HID yet. heres a basic how to.
Items needed:
1 can of spray paint
Epoxy
Silicone
Flathead screw driver
Factory Fog lights or other projector
1. Remove center of fog lights from outer shell. Clips on both sides, you can use a flathead to gently pry them undone.
2. Remove bulb from fog lights and cut right before the area where the bulb slides into light. I used a dremel tool with a cutoff wheel. Try to make cut as straight as possible, if it isn’t perfect its alright.
3. Remove headlights from car and disassemble the same way you would if you were to do clear corners mod.
4. After headlight disassembly look at the area where the low beams are and you will notice that there is a flat area where the bulb sits, then angles on both sides. You need to trim the fog lights or projectors to be able to sit on there as flush as possible. You also need to take out the piece that wraps around the low beam bulb; it just pops out if you squeeze the sides.
5. Next you can test fit the projectors, make sure they sit flush and use epoxy to fasten them in place.
6. Let dry for 30-40 minutes, after the epoxy fully dries, you can mask off the projector lens and the high beam area and pain the low beam area black. You don’t need too, but I think it just gives it a cleaner look.
7. Wait for paint to dry and reassemble, make sure you seal the headlights properly with the silicone or they will fog up when it rains.
Old 08-04-2006, 07:30 PM   #7
burg03
I gues I am on my way
Old 08-04-2006, 07:54 PM   #8
alerocar01
alerocar01's Avatar
alerocar01 is an unknown quantity at this point
thats awesome. I need a how-to! the only thing i am wondering is how well they are aimed on the ground
alerocar01 is offline   Reply With Quote
Old 08-05-2006, 12:02 AM   #9
olds03alero
well i ran into a problem, after having them at night, they are nowhere near bright enough to drive with. i have silverstars in them, but i am gonna try to redo the mirror finish inside of them. they seemed kinda dark after i cut them. i'll give it a shot but if it doesn't work i guess i need another set of headlights.
Old 08-05-2006, 12:14 AM   #10
LOL, maybe you shouldn't have painted the inside there...maybe you need HIDs
Old 08-05-2006, 12:16 AM   #11
Let us know, I'm liking
Old 08-05-2006, 12:19 AM   #12
olds03alero
i think i need HID's, but the cheapest set i've found is $215. its a little more than i wanna pay right now. i think i'll try to fix it and put low beams in the high beam area to at least be able to drive for work.
Old 08-05-2006, 12:20 AM   #13
well, it just so happens i know somebody with an extra set of headlights laying around...LOL I was actually going to tear those shits apart and do the same thing you are now...
Old 08-05-2006, 12:26 AM   #14
olds03alero
how much do you want for them, i need to perfect my idea and having a spare set would help a lot.
Old 08-05-2006, 12:28 AM   #15
i dunno, as i said i'm planning on installing projectors as well so i can put my hids back in...
Old 08-05-2006, 02:47 AM   #16
So if i am figuring this right, you used the projectors from the factory fog lights for the low-beams? no wonder you can't see anything at night. If you get a good set of halogen projectors you won't have that problem. I have the Hella 90mm projectors on my chevy and they are WORLDS above the stock headlights.
Old 08-05-2006, 03:22 AM   #17
olds03alero
yes i did, i got the idea from a few guys over at grandamgt.com they did basiclly the same thing i did. They did it without any problems, i think i just screwed up somewhere. i dunno i think i can fix it but i gotta wait til morning,
Old 08-05-2006, 09:08 AM   #18
blackdog
blackdog is an unknown quantity at this point
One head light has more black then the other almost looks like they are not even but I have the same question, are they aimed right?
Car Part out: http://www.aleromod.com/forums/showt...478#post345478
eBay Auctions: http://motors.search.ebay.com/_W0QQsassZa27283
Cars: 2006 Toyota Matrix, 2008 Dodge Caliber SRT4
blackdog is offline   Reply With Quote
Old 08-06-2006, 12:33 AM   #19
peeweeherman
peeweeherman's Avatar
peeweeherman is an unknown quantity at this point
Send a message via AIM to peeweeherman Send a message via MSN to peeweeherman Send a message via Yahoo to peeweeherman
Would those look good on a red car
peeweeherman is offline   Reply With Quote
Old 08-06-2006, 12:36 AM   #20
blackalero99
blackalero99 is an unknown quantity at this point
nice man
COME GET SOME
blackalero99 is offline   Reply With Quote
