Old 08-08-2006, 02:26 AM   #1
N1ck3r
N1ck3r's Avatar
N1ck3r is on a distinguished road
Colour match?
Well its to do with the LED's i'm hoping to obtain and the white alero i've got.I am looking for some input on what colour the LED's should be to compliment the car. I'm thinking Blue or possibly white? Any suggestions would be great full. (This is for both interior and exterior).
As well, i'm looking for a sweet place to hide the switches for the lightning, and possibly change the dome light and cubby hole light with the same colour light as the LEDs.
On another note, i've seen pictures with the amber turn signals swapped, for blue lights? Is this illegal everywhere, or even at all?
N1ck3r is offline   Reply With Quote
Old 08-08-2006, 07:52 AM   #2
_01Alero_
A.S.S. Translator
_01Alero_'s Avatar
_01Alero_ is an unknown quantity at this point
I know that the blue lights in the turn signals are illegal here in indy. But, I know that some of the lights you are referring to are probably the invisible lights that you can get off of PFYC.com. Those are pretty awesome turn signal lights, and if you clear your corners, then definetly get those.
Im not sure on the led color. Blue or white would be good depending on what you wanted to do under the hood with color and the interior design. You could do blue and white. I think some of the led kits, you can switch each stick to a different color, and you may be able to do blue and white. But go with what you are going to do with the rest of your color scheme.
_01Alero_ is offline   Reply With Quote
