Old 08-17-2006, 10:03 PM   #1
jabartram
AutoCross Alero
jabartram's Avatar
After 2 months of waiting
and reading through the forum to learn a little, buying a laptop specifically for it, i got it today. i'll start working with it this weekend.
Old 08-17-2006, 10:04 PM   #2
acold7dusta
nice, tell us the improvement once your all tuned
Old 08-17-2006, 10:21 PM   #3
jackal2000
jackal2000's Avatar
i bought one two days ago. sure as hell better not take that long to get here.....
Old 08-17-2006, 11:28 PM   #4
alero_ecotec
Special Agent
alero_ecotec's Avatar
alero_ecotec is an unknown quantity at this point
i assume this is for the 3400?
THE Ohio State University!
alero_ecotec is offline   Reply With Quote
Old 08-17-2006, 11:34 PM   #5
yes, it's for the 3400.
Old 08-18-2006, 08:01 AM   #6
jackal2000
jackal2000's Avatar
thats a good assumption considering where he posted. lol
Old 08-18-2006, 08:04 AM   #7
mfuller
Good luck....read the forum, tuner guide, and do tons of other research before you change anything. Only change 1 thing at a time....I've been monkeying with my PowrTuner for about a year now.....it's incredible the amount of stuff you can change.
Old 08-18-2006, 09:57 AM   #8
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
the only thing i would hate about those is you have to use premium fuel as long as you have that thing in your car.......uggg, i would hate that but i bet the extra HP you would get may be worth it
Old 08-18-2006, 10:14 AM   #9
mfuller
Not necessarily....
You can tune it exeactly how you want....if you don't want to be forced into premium fuel, then don't advance the timing - but you can still play with tranny settings, speed and rev limiters, fan turn on points, fuel trims, and all that jazz.
For instance, I have stock timing and fueling in my car....granted, I still need to use mid-grade gas, but that's mostly due to high-mileage (over 110K) and milled cylinder heads that nudged my compression ratio up a bit (about 10:1; stock is 9.5:1).
Old 08-18-2006, 10:30 AM   #10
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
ahhh, didnt know that, thanx for the info ^_^
Old 08-18-2006, 12:15 PM   #11
jturkey69
jturkey69's Avatar
jturkey69 is an unknown quantity at this point
Send a message via Yahoo to jturkey69
what is the lowest operating sysytem you can run for the laptop??
matt...where would you start as a tuning point?
OCA Alero Chapter Member!!!!
ALERO-LESS
jturkey69 is offline   Reply With Quote
Old 08-18-2006, 12:32 PM   #12
Satsuriku
V.I.P. Punching Bag
Satsuriku's Avatar
it depends on the stats of the laptop.....you wouldnt want to try and put windows xp on a 855mhz lap top...if you have a P4 then just put xp on it and it should be fine
Old 08-18-2006, 03:59 PM   #13
burg03
letme know how it all goes. Would you recomend getting all that stuff Fuller
Old 08-18-2006, 06:35 PM   #14
I'm running XP (SP2) and my PowrTuner on a P2 400mhz. What's the issue?
Now for the rest, dont get confused between the DHP PCM and the DHP PowrTuner. One is a preprogrammed PCM, the other is a tuner to PROGRAM the PCM.
Old 08-18-2006, 07:06 PM   #15
jackal2000
jackal2000's Avatar
yea, there is also a $300 price difference lol
Old 08-19-2006, 12:05 AM   #16
-Alero-
-Alero-'s Avatar
i would jus dyno tune personally.
AUTOBOT
Old 08-19-2006, 01:57 AM   #17
-Alero-
-Alero-'s Avatar
although it would be cool to drive around with a lap top in your car. kinda liek a cop. except you could see your entire engine powertrain.
AUTOBOT
Old 08-19-2006, 11:59 AM   #18
jackal2000
jackal2000's Avatar
dont most shops require you to have your own tuning software?? i know the one in NC did and the one i am going to requested i bring my own....
Old 08-20-2006, 03:38 PM   #19
burg03
what shop you are going to
Old 08-20-2006, 04:18 PM   #20
jackal2000
jackal2000's Avatar
b and t motorsports
