Old 09-01-2006, 06:33 PM   #1
Wildman
Wildman's Avatar
Wildman is an unknown quantity at this point
P0420
Ok, it means Catalyst efficency below threshhold...or something like that. Anyways, I was wondering if anyone else has had this and what they did to correct it. I keep getting this code a few days after I clear it out, so it's not a one time thing......
CAI - Borla Cat-back - S&S Headers - DHP - AFPR
Wildman is offline   Reply With Quote
Old 09-01-2006, 07:30 PM   #2
jabartram
AutoCross Alero
jabartram's Avatar
i had the same problem after my high flow cat was installed, i installed an o2 sim, and it has been ok, but i just disabled my bank 2 o2 sensor, with my PT, if all is good, i may sell my o2 sim.
Old 09-01-2006, 07:34 PM   #3
jackal2000
jackal2000's Avatar
PT owns
perhaps your cat is clogged?? i dunno.
Old 09-01-2006, 11:31 PM   #4
number1alero
number1alero is an unknown quantity at this point
i got the same code when my catalytic converter went bad...it was replaced under full warranty so thankfully it didnt cost anything
number1alero is offline   Reply With Quote
Old 09-02-2006, 12:01 AM   #5
IF the cat isn't clogged just get the o2 sim
Old 09-02-2006, 07:02 AM   #6
Yep, basically means that the converter isn't converting enough. Check if your car is still under emissions warranty and you may get it replaced free.
Old 09-02-2006, 01:07 PM   #7
Wildman
Wildman's Avatar
Nothing is under warranty, it's a 99 with 93,000 miles. Besides, I've got headers in front of the cat, and borla behind it. Looks like I'll be searching for a very short cat. Is high flow really better? or Should I just stick to a regular cat so as to not have any O2 sensor issues.
Old 09-02-2006, 01:11 PM   #8
jackal2000
jackal2000's Avatar
are your headers coated? if it was a poor coating job they could have flaked and clogged the cat. if that is the case, i would be calling s&s....
Old 09-02-2006, 01:54 PM   #9
jabartram
AutoCross Alero
jabartram's Avatar
if you have headers and highflow cat you will have bank 2 o2 problems.
Old 09-02-2006, 02:43 PM   #10
Wildman
Wildman's Avatar
Well I guess we won't know that till I remove the cat. I havnt heard anything like this from S&S headers. I thought that was some of the early TOG headers that had that issue....
Old 09-02-2006, 03:05 PM   #11
jackal2000
jackal2000's Avatar
it was, but ya never know.
Old 09-04-2006, 09:45 PM   #12
Spilner521
Boost Guru
Spilner521's Avatar
Like others have said, sounds like a bad cat. Get a Magnaflow OBD-II high flow cat to replace it and you'll be fine. I have 3" piping from the turbo-back with a 3" Magnaflow cat and never had any codes.
Old 09-05-2006, 03:33 AM   #13
No Alero has any Bank 2 Oxygen sensors..
Old 09-06-2006, 08:42 PM   #14
Wildman
Wildman's Avatar
Ok, so I'm thinking that maybe I could just hollow out the cat, and put an o2 sim on it to prevent any codes.... In PA for inspection, as long as the cat is physically there, it will pass the visual inspection. And as long as there are no trouble codes, it will pass the OBDII emissions test. Anyone see anything that I am not thinking of in this new plan ??
Theoretically, if I threw on an o2 sim right now, I wouldnt see any codes no matter what condition the cat is in right??
Old 09-06-2006, 09:20 PM   #15
jackal2000
jackal2000's Avatar
sounds right to me. the more expensive route is like jabartram stated, diabling the bank o2 sensor in the pcm with a powrtuner.
