Old 09-19-2006, 12:10 AM   #1
-Alero-
-Alero-'s Avatar
Plug input
yo! i need new spark plugs........ again. this will be my 4th set and i only have 68k on my 2002
my question is - is there any other spark plug besides those OEM denso iridiums that outlast 30k miles? ive had no luck with the OEM ones. anyone suggest any?
the ones i have in now are missfiring in the top end, and making it difficult at cold starts.
also anyone have a suggestion on a type or brand of brake pad i should use for my rear. im about to change rotors and pads.
AUTOBOT
Old 09-19-2006, 12:23 AM   #2
SweetNLow
SweetNLow's Avatar
if your going on your 4th set you have some other problem most likely causing your plugs to foul out. are you sure its your plugs though.... what makes you think it is for sure the plugs
i replaced my plugs at 85k with ac/delco oem's and didnt really notice much of a difference. just starts a tad better.
joelsoundxtreme: u faggot
