Old 09-22-2006, 04:14 PM   #1
comanche
comanche is an unknown quantity at this point
2.4 Rebuild
Well, since I replaced the 2.4L in my Alero, I now have the old one to work with. (It runs, but prob. has bad main bearings. I have access to a new crankshaft it the old one is bad.).
I'm just wondering what I could add for significant performance increase without spending above $300 on extras.
I have lots of auto recyclers to choose from, so if there are any really good 2.3 parts, that might work.
Any ideas?
comanche is offline   Reply With Quote
Old 09-22-2006, 08:45 PM   #2
Spilner521
Boost Guru
Spilner521's Avatar
I'd tear it apart and check and see if there was any other damage besides to the crank. If everything looks good, clean it all up before putting everything back together. As far as performance goes, you could go with a 2.3 High Output intake manifold, cold air intake, a header and a full header-back exhaust with a high flow cat.
Old 09-22-2006, 10:49 PM   #3
Oldsman
Owner
Oldsman's Avatar
also get the 2.3 secret cams, 2.3 HO TB and then have at least a mild polish and port job to the head and you will get some good gains
Beware of the BackStabber
Old 09-23-2006, 11:20 AM   #4
comanche
I'm planning on the HO manifold, secret cams, and CAI. What header and what cat-back exhaust would be best? (Price/best value is important)
Old 09-23-2006, 01:06 PM   #5
steve-o
Canadian... Eh?
steve-o's Avatar
steve-o is an unknown quantity at this point
Send a message via MSN to steve-o
secret cams, whats so secret about them????
steve-o is offline   Reply With Quote
Old 09-23-2006, 01:30 PM   #6
Oldsman
Owner
Oldsman's Avatar
either pacesetter, OBX, or rksport. for cat back i would say either a custom exhaust or borla. cause SLP sounds like crap on a 2.4
Old 09-24-2006, 02:08 PM   #7
Spilner521
Boost Guru
Spilner521's Avatar
With price in mind, I'd go with the pacesetter header and a custom exhaust. Instead of making just the cat-back part of the exhaust, make it from the header-back. If you're serious about the secret cams and port and polished head, I'd go with 2.5" exhaust piping. If you only plan on the cams, it may be better to go with 2.25". If you get the pacesetter header, the B-pipe steps down to the stock 2" exhaust at the end. Just cut that part off and start with the new piping, go into a high flow cat, through a resonator and then over the axle to the muffler. Make sure the muffler and resonator are straight through for maximum flow.
Nothing anymore Just easier to say "secret cams" than "1995 LO intake cam and pre-1995 LO exhaust cam".
Old 09-24-2006, 09:53 PM   #8
battistoni21
battistoni21 is an unknown quantity at this point
Send a message via AIM to battistoni21
good luck with everything man....
not to get off topic, but Spilner, if i post a pic of the pacesetter header for the 2.4, could you show me where the cut the 2in part at?
battistoni21 is offline   Reply With Quote
Old 09-25-2006, 07:50 AM   #9
comanche
Which pacesetter header? Would it be worth it to spend $100 more to get the ceramic-coated header? And how do you know which highflow converter and which resonator to get?-is that an issue? Thanks, this has helped a lot.
Old 09-25-2006, 09:04 AM   #10
comanche
Also, I can use my old lifters with the new cam, right? I don't need to use the 2.3L lifters?
Old 09-25-2006, 06:14 PM   #11
Oldsman
Owner
Oldsman's Avatar
^^^correct
Old 09-26-2006, 07:50 AM   #12
comanche
"Would it be worth it to spend $100 more to get the ceramic-coated header? And how do you know which highflow converter and which resonator to get?-is that an issue?"
So now I need to start gettting all the pieces together: cams, manifold, exhaust, other gaskets, CAI. This is going to be a lot of fun, not.
Old 09-26-2006, 07:39 PM   #13
Oldsman
Owner
Oldsman's Avatar
yes it worth it for cermanic coated.
for high flow cat and resonator (if you want......i don't have one) go with magnaflow.
Old 09-27-2006, 08:36 AM   #14
comanche
Thanks. One more question, I'm assuming that these mods will bring the 2.4L up to at least the power and torque of the stock 3400, is that true? (Also, is there any difference between the $185 pacesetter ceramic headers offered by PFYC and the $260 pacesetter ceramic headers offered by AAS?)
Old 09-27-2006, 04:39 PM   #15
Spilner521
Boost Guru
Spilner521's Avatar
Actually I just looked at a pic of it. I was mistaken. I thought I'd seen a different picture where the B-pipe steps down to the stock pipe size but it doedsn't. I'm not sure the diameter of the B-pipe that comes with it, but if it's not the same size as your exhaust, just cut it right after the flange that connects to the header and have a tube welded on that is the same diameter and then connect it to the exhaust.
Old 09-27-2006, 11:15 PM   #16
Oldsman
Owner
Oldsman's Avatar
just price
Old 09-28-2006, 12:28 AM   #17
battistoni21
good find..... i bought mine for a total of 285 off of ebay......
