03-15-2004, 03:35 PM
Swank
On several occasions I've been doing work in my car and I need the driver's door open, and I also wanna listen to the car stereo but I DON'T wanna listen to that damn 'bing, bing, bing' the whole time. Any easy way around this? (I couldn't find any previous posts on this chime).
03-15-2004, 03:43 PM
Does it still chime on ACC instead of ON?
03-15-2004, 03:44 PM
Swank
Yep, it chimes no matter to what position the key is turned, even 'OFF'.
03-15-2004, 04:26 PM
why not rig something to hold down the door sensor?
03-15-2004, 05:51 PM
aka duct tape :thumbsup:
03-15-2004, 06:12 PM
Swank
I didn't even notice a door pin, otherwise it would have reminded me of when I used to jam a tennis ball in there like I used to on my Mustang. Thanks for jogging my memory! The easiest solutions are sometimes the best.
03-15-2004, 10:08 PM
I don't know about your ignition, but I can pull the key out of mine. I just turn it to ACC and pull the key out a bit until it stops dinging.
03-15-2004, 10:28 PM
^^ You're not supposed to be able to do that. It's actually a DOT reg.
03-15-2004, 11:15 PM
Originally posted by Redog+Mar 15 2004, 09:28 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Redog @ Mar 15 2004, 09:28 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-AleroRyda@Mar 15 2004, 10:08 PM
^^ You're not supposed to be able to do that. It's actually a DOT reg. [/b][/quote]
I think I can do that with mine too. On my old car I could actually just take the key all the way out no matter what position it was in. Yep, that thing was a POS.
03-16-2004, 11:09 AM
Swank
I took a quick look for a door pin and couldn't see anything. Where is this sensor/switch located?
03-16-2004, 01:01 PM
I think it inside the door
2002 GL2 4DR, MYMODS:In dash 7" VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10" Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
03-26-2004, 10:32 AM
I had an 87 Olds Delta 88 with the 3800 engine. damn i miss that thing, but before i got into a wreak with it i was driving on the highway doing about 70 and hit a small bump in the road. the keys went BOOP out of the ignition. at the end of her life cycle i didnt even need the key anymore. man i miss that thing! :wah:
03-26-2004, 01:52 PM
The Founder
just get an aftermarket head unit.... and don't relocate the stock on. Bam, no more chimes.
04-03-2004, 04:04 AM
Originally posted by Redog+Mar 15 2004, 10:28 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Redog @ Mar 15 2004, 10:28 PM)</td></tr><tr><td id='QUOTE'><!--QuoteBegin-AleroRyda@Mar 15 2004, 10:08 PM
^^ You're not supposed to be able to do that. It's actually a DOT reg.[/b][/quote]
I just found out my key comes right out in any position (haven't tried while driving tho). I know the ignition is a little worn but what's happening here?
04-03-2004, 08:10 AM
Your ignition switch or Key needs to be replaced. My mom had a 98 Malibu that done the samething, and they had to replace the whole switch. Also a worn key can cause this to happen also. Try going to a GM dealer and having a new key made from your VIN and not a copy of your old key.
2005 Honda CR-V AWD
