Old 10-06-2006, 12:05 AM   #1
AleroMike87
AleroMike87's Avatar
AleroMike87 is an unknown quantity at this point
weird power problem
hey, i dont know what to do right now, my car was whineing recently and the lights were dimmings, my car didnt start a couple of times, and then it did, seemd like there was a problem with my alternator, got it checked, its good, got my battery checkd, its good, my car is getting no power at all through my battery or even my moms, at first when i hook it up, there is only the smallest spark on the negative. but i get no power, then i unhooked it and hooked it up aagain and nothing, not even a spark, now i put my moms battery back in her alero, and NOTHING, no power to her car either. how did my car screw up my moms battery just from hooking it up? i washed my engine bay out last week, what could have caused this? what should i do?
plz help guys, thanks mike.
AleroMike87 is offline   Reply With Quote
Old 10-06-2006, 12:26 AM   #2
Were the termails clean? not the battery's the car's
Were they cracked, broken, or messed up in anyway?
That's all I can think of, unless you have a short somewhere
Old 10-06-2006, 12:55 AM   #3
mike k
could be that your alternator shorted and took the battery along with it.
Old 10-06-2006, 07:53 AM   #4
robz02alero
robz02alero's Avatar
robz02alero is an unknown quantity at this point
Send a message via Yahoo to robz02alero
I would swing test a 3rd battery from somewhere else that you are positive is a good battery. If the same thing happens then you know you have a problem other than the battery. When you cleaned your engine did you cover up the important parts i.e. electrical boxes, alternator, battery...they usually don't mix well with water. I've cleaned my engine compartment many times and never had this problem. I would get a second opinion on that alternator. Usually when it starts whining and lights start dimming the electrical brushes inside are failing. good luck.
owner/operator of : The Pinnacle of Clean Auto Detailing Service www.pinnacleofclean.blogspot.com
Supporter of Aleromod.com
OIF VETERAN X3
COMING HOME SOON
robz02alero is offline   Reply With Quote
Old 10-07-2006, 04:06 PM   #5
AleroMike87
arrite i got it fixed it was my battery and my connection cables, i got an optima yellow top, everything seems to be good now.
