Old 03-16-2004, 12:06 PM   #1
99AleroinAz
Hey everyone,
My 99 Alero with 77,000 miles on it is making the old hinge on door typing groan as I make turns left and right off the front end. It appears that I can hear it in the car but not while out of the car. Any recommendations. The dealer says shocks and struts are fine which I dont believe is true. Also when my back right tire hits a speed bump, you hear this loud sqeak type sound...any help there???
Thanks, and I really do appreciate any feedback!
Jason
jasonpswenton@aol.com
Old 03-16-2004, 12:32 PM   #2
justinusaf
justinusaf is an unknown quantity at this point
Send a message via AIM to justinusaf
I have the same sound coming from the back drivers side. Just sounds like the springs creaking. I have intraxx lowering springs. Doesnt seem like a problem though.
Pheenz Motorsports Founder
justinusaf is offline   Reply With Quote
Old 03-16-2004, 12:51 PM   #3
wy3134
I have the same problem with my rear passenger side....I can definetely tell its either the shock or strut that needs replaced, but it will have to wait until weather gets better to be fixed <_< another $100 down the drain for pointless GM crap replacement **prays he can talk the dealer into GM performance parts to replace stock crap** (realistically knows wont happen)
Old 03-16-2004, 12:55 PM   #4
99blackalero
its not the strut....its the hub that needs replacing i think or jsut needs to be lubbed....mine was squeaking, and my shop gave it some wd-40, and it cleared up in a week or so
Old 03-16-2004, 01:27 PM   #5
freeze12
Stabilizer Bar Bushings will do this. Get under the car & spray the bushings with Lithium grease or replace with Polyurethane Bushings.
...Dan...
Old 03-16-2004, 01:31 PM   #6
99blackalero
thats what they're called...i had a brain cramp on that one
Old 03-18-2004, 11:16 PM   #7
99AleroinAz
Ok I will try that.
What about the major squeek i hear when I hit a speed bump on my back right tire.... Its very apparent when people are in my back car, If i hit a bump, I hear the squeek..
Thanks again,
Jason
