Old 10-13-2006, 06:34 PM   #1
sofa
sofa's Avatar
sofa is an unknown quantity at this point
Send a message via MSN to sofa
Heat door Location
It is now really cold and snowing heat must go on lol. Can somone tell me where the heat door/tempuature control is located in the aleros duct work. Is it directly behind the radio cluster? and if anyone knows is it controled by vacuum or electronics? Thanks for ur help
Straight.From.Steel.City
http://www.cardomain.com/ride/2313940 http://www.myspace.com/kowch
sofa is offline   Reply With Quote
Old 10-18-2006, 09:54 PM   #2
Frank3
A Temperature actuator is used to modulate the temperature/heat door. It appears to be electrically operated by what I see in the FSM.
Old 10-19-2006, 11:09 PM   #3
sofa
sofa's Avatar
Thanx man..i ended up finding it.
Old 10-19-2006, 11:53 PM   #4
super white alero1
Trying to get it together
super white alero1's Avatar
the actuator is vacuum control located behind the glove box. The dealer call this the temperature actuator. Make sure you tell them this or you might get the mode door actuator which control the vent and not the temperature.
