Old 10-15-2006, 01:04 PM   #1
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
alero wiring..
hey.. i'm an idiot..
i cut off the stock wiring harness.. well i kind of wised up and put it back on.. but i dont know what wires are what when it comes to those 2 purple ones that are the exact same color. what do they do? are they important?
another thing is.. is that i have it wired up to where it doesnt come on with my ignition, it comes on with me hitting the button, or its always on (there is no ignition wire coming from the car.) how do i get it to do it right? do i need that 80 dollar thing from crutchfield?
this thing.. class II bus thingy???
http://www.crutchfield.com/S-dz0sEjl...51&I=120GMRC01
white04alero is offline   Reply With Quote
Old 10-15-2006, 04:22 PM   #2
mike k
Make sure you get you wiring hooked back up correctly. Also it is a good idea to get the harness from Crutchfield. It is a class 2 data connection. Your factory radio is wired thru the Class 2 Data Bus. Which means so are your Airbags, Doorlocks and any other function on that Data circuit.
Old 10-15-2006, 08:48 PM   #3
white04alero
well everything still works..
its just that i have to turn on my stereo.. and the chimes went away.. but my auto door locks work..
and so does everything else
Old 10-16-2006, 02:45 AM   #4
You might have the purple wires backwards. I know for a fact that the Class 2 wire is purple.
Old 10-16-2006, 08:14 AM   #5
sound_xtreme
sound_xtreme's Avatar
run your own. You could tap into the orange wire at your ignition switch harness.
Cardomain
