10-24-2006, 06:25 PM
alpine subs
i am loioking to get 2 alpine type r's to run one ohm so i know i will need the 4 ohm subs but what would be better the 10's or 12's?
FEATURES
Woofer 12" - • Bumped Backplate
- • Compound Radius Curve Pole Geometry
- • Custom Cast Aluminum Frame with Integrated Heat Transfer Plate
- • Designed and Engineered in the USA
- • Dual Progressive Oversized Nomex ® Spiders
- • Dual Stacked Magnets
- • Dual Voice Coil Design
- • Extra Length Extended Pole
- • Flared Pole Vent
- • High Strength Brass Voice Coil Bobbin
- • Integrated Tinsel Lead Design
- • Kevlar Reinforced Pulp Cone
- • Magnetically Optimized Motor Structure (Pat. Pend.)
- • Oversized Parabolic Dustcap
 SPECIFICATIONS
Power Handling - • Power Handling Capacity (Peak) : 1500W
- • Power Handling Capacity (RMS) : 500W
General - • Diaphragm Material : Kevlar Reinforced Pulp
- • Spider Material : Nomex
- • Frequency Response : 23Hz - 500Hz
FEATURES
Woofer 10" - • Bumped Backplate
 SPECIFICATIONS
- • Frequency Response : 24Hz - 500Hz
heres the specs. and thanks alot for any help i can get
1999 Oldsmobile alero 3400 sfi
10-24-2006, 09:45 PM
anybody??
10-24-2006, 09:54 PM
A.S.S. Translator
What kind of music do you listen to most shackney?
*Edit* I guess it really doesn't matter what music you listen to, I would go with the 12" Type R's. Reason for me saying that is that you are getting a better range out of the 12" (of course only 1 more Hz) but who knows. Either sub would work fine so....up to you man.
10-24-2006, 10:03 PM
i listen to mostly rap and i have a kicker 1200.1 amp the specs look same to me and i was thinking 10 just cuz they cheaper but i dunno what would truly sound better
10-31-2006, 02:47 PM
definately go with the 12's, 10" type r's arent good for rap. I tried one out and ended up selling it after about a week
11-17-2006, 05:01 PM
i just got my 12's in today type r's. My amp is a mono and only has one spot for subs...what is best way to wire the subs? to get the subs to 1 ohm they have to be wired together then one set of wire ( +-) to the amp
11-17-2006, 05:30 PM
bull. it's all in the box.
11-17-2006, 11:50 PM
those type R's are proven to handle 1000 watts, i would prolly just buy on and make a big ported box with 1200.1 and call it a day. they can hit high 140s in the right box
11-18-2006, 01:26 AM
yea go wit ported box becuz u will be pushin out more bass
11-18-2006, 01:36 AM
sound xtreme what box do you recommend?
11-18-2006, 07:29 AM
i plan on goin ported just gotta get some time to make my box
12-06-2006, 08:47 PM
i had 2 12" type R's. was going to sell them. Wasn't too pleased. Going with 2,3, or 4 10's. I listen to techno though. Sharpness is what I am looking for. However, those subs got stolen... thanksgiving night this year.
12-06-2006, 09:03 PM
i have a pair of 12" type r and one of those gimmicky boxes that can be ported or not. I know that the ports arent set up right and thats why it might sound poor with them. But imo the type r's sound way better in a sealed box.
12-06-2006, 09:36 PM
I have 2 12" Type S subs in a HUGE Baseworx box (ported) (800 watts) with a 800watt Alpine V-Power mono amp, and 2 alpine 6*9's Type S speakers and 2 alpine 4 1/2 Type S speakers in the front, running off of my Alpine deck, all together pushing 1000 watts and I listen to pretty much everything from rap, techno, rave, rock, little country....but they are awsome...wish I could afford the Type S but I think next month im getting possably 2 Type X subs and 3000watt amp(s). lol, nvr turn up the volume all the way if u have type x's, say good bye to battery, backwindow etc.
12-06-2006, 09:40 PM
ported, nice big fat ported box
12-06-2006, 09:41 PM
Sealed boxes provide a flatter response in general. Thats what your seeing as better sound, its more linear.
As for output, Mark Potts did 154 with a single 12" Type R.
So the subs are very capable. As noted, its in the box.
If you want your sub to fart one note, or you want them more musical.
Its car audio. Not rocket science.
I got a member on my board thats very happen with the Type R. Seems to be a rather stout sub that can do good things.
As for boxes, I believe he is reccomending 3 cubes tuned to 30Hz, after displacement. It would appear to be more musical than gain oriented @ 30 hz. If your listening mainly to newer rap with high Hz bass, you could tune higher. Say 38Hz..
12-06-2006, 09:47 PM
Oh and use your system carefully, Im pushing 98DB's in my Alero and friends have complained almost going def...lol...and don't advertise, thats how I got my old system from my old Probe stolen *totaled more than a month ago*
12-06-2006, 10:18 PM
at least turn ur effing system down when ur near ur neighbor hood. u never know what type of trash is living around there....
12-06-2006, 10:20 PM
98? wow. i used to roll 140+ everyday. thats where most of my hearing damage came from though.... :/
12-07-2006, 09:30 PM
COmmon sense at its best. To bad its not so common... lol
