Old 10-29-2006, 07:45 PM   #1
blackalerocar
blackalerocar is an unknown quantity at this point
Send a message via Yahoo to blackalerocar
Wtf
Ok I had to move my car and noticed that my brake light does not work when I apply the brake but the light is lit while the lights are on? Is it the bulb? It's still lit while the lights are on...I dunno. Any suggestions?
blackalerocar is offline   Reply With Quote
Old 10-29-2006, 08:04 PM   #2
p1mptress
I'm pretty much Awesome!
p1mptress's Avatar
p1mptress is on a distinguished road
Send a message via AIM to p1mptress
Yea most likely the brake light bulb is blown
p1mptress is offline   Reply With Quote
Old 10-29-2006, 09:32 PM   #3
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
^ on the outers, it's the same bulb. replace the bulbs and you should be fine.
question, is the 3rd light (center) working properly? if so, it's the bulbs. if not, make sure the 3rd light's bulbs are okay. if that doesn't solve the problem, you have a wiring issue.
Old 10-29-2006, 10:25 PM   #4
super white alero1
Trying to get it together
super white alero1's Avatar
Check the fuse in the dash.
Old 10-29-2006, 10:26 PM   #5
jlong
jlong's Avatar
jlong is on a distinguished road
It could be the brake light switch.
jlong is offline   Reply With Quote
Old 10-29-2006, 10:30 PM   #6
super white alero1
Nope not brake switch. If that was the case, you cannot shift from P to R or D
Old 10-29-2006, 10:46 PM   #7
jlong
jlong's Avatar
Not true, well at least I think. On my truck (chevy colorado) the brake light switch went out and there is a recall on it. I could shift from park to drive just fine. The only way to tell the switch was bad is the cruise control would not work, or someone would tell you your brake lights were not working.
