Old 10-31-2006, 03:44 AM   #1
redblur_2001
B&M short throw again
Does the B&M short throw come with the new shifter cables, if you order it online?
Old 10-31-2006, 07:46 AM   #2
Mischief007
Mischief007 is an unknown quantity at this point
Send a message via MSN to Mischief007
You don't get shifter cables with any of the short throws. It replaces your stock shifter. You never replace the shifter cables.
??,??? km
??,??? miles
Mischief007 is offline   Reply With Quote
Old 10-31-2006, 05:41 PM   #3
redblur_2001
oh ok, then should i order better shifter cables for the short throw B&M instead of using the stock 2.4L cables?
Old 10-31-2006, 08:13 PM   #4
Mischief007
Use stock. The only part that is replaced is the shifter itself. Just shortens the throw of the shift, of course .
Use the stock ones .
??,??? km
??,??? miles
Old 10-31-2006, 09:01 PM   #5
redblur_2001
kool will do thanx man
Old 11-01-2006, 02:57 AM   #6
There's also a "Quickshift" arm that you can install on the transmission to shorten the throws even further. Unfortunately I haven't found any US reseller that carries it. (the same trans is used in Vauxhalls/Opels in europe)
