Old 11-01-2006, 09:48 PM   #1
siether
siether is an unknown quantity at this point
Soft brake pedal
It started today, on my way to work my brake pedal felt fine. But when I left work in the afternoon my pedal feels soft. It almost goes all the way to the floor now. The brakes still work but I need to brake way ahead. My fluid was a little below max and I topped it off, and I checked my parking spot and didn't find any spots on the ground that looked like leaking fluid. Has anyone else had this problem, if so what was it? Any sugestions would be great.
siether is offline   Reply With Quote
Old 11-01-2006, 11:09 PM   #2
super white alero1
Trying to get it together
super white alero1's Avatar
Brake master cylinder probably has an internal leak.
Old 11-01-2006, 11:51 PM   #3
DUDE i had the same problem in my taurus, and it was because i left my E BRAKE on, i eventually noticed it and i pulled it out, and everything went back to normal. Make sure thats not itlol
Old 11-02-2006, 07:46 AM   #4
alero168
I Love Tiara!
alero168's Avatar
alero168 is an unknown quantity at this point
Send a message via AIM to alero168
when was the last time you changed your brake pads? sometimes it's just common problems well not as common as billy's but....
do you hear anything when you brake?
alero168 is offline   Reply With Quote
Old 11-02-2006, 08:22 AM   #5
siether
I don't hear anything when I brake. No sqweaking. I'm kinda thinking it's the master cylinder also. Plus I haven't used my e-brake at all and the handle is all the way down.
Old 11-02-2006, 10:00 AM   #6
O ok, well i just figured i would tell you my stupid story in case u did the same thinglol but nobodys as stupid as me on here
Old 11-02-2006, 10:22 AM   #7
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
whatever it is, you definitely lost pressure somehow. check to make sure the e-brake is fully disengaged. Then check for any leaks/puddles under the car (could be a leak in the master cylinder, or the brake lines MIGHT have a small hole from corrosion). Then check the condition of the pads.
if it's not any of those, you have a serious problem.
Old 11-03-2006, 01:44 AM   #8
mustang_killer
It's Shake 'n' Bake Time
mustang_killer's Avatar
mustang_killer is an unknown quantity at this point
Send a message via MSN to mustang_killer
Usually with a soft pedal its the second, I think, Seal in the master cylinder. If it stops and then slowly sinks thats pretty much the cause. If it goes almost to the floor, but slows the car down alittle. It might also be air in the brake lines. Cause if its just air in the lines, its pretty easy to bleed out.
mustang_killer is offline   Reply With Quote
Old 11-03-2006, 02:40 AM   #9
Clean the inside of your wheels a bit, and pump the brakes. If you have a leak around the caliper, that's where it's going to drip.
That's what happened to mine
