11-08-2006, 01:35 AM
Injectors?
Are 36 lb fuel injectors just alittle to much for a 3400
11-08-2006, 01:54 AM
i would only upgrade to 36 lb injectors if you get heads and a cam stuff like that
->Current Mods:CAI,S&S headers,High Flow Cat,2.5 pipe from headers back,maganflow Muffler,intrax springs,18" Chrome rims,MMS stage 2 performance package
11-08-2006, 09:02 AM
but even then you should check the duty cycle to see whats what.
11-08-2006, 09:10 AM
all depends on what else you've done to it, like the other two said.
If you're totally stock with a few bolt-on mods, then it's not worth changing them. Plus, you're going to have to retune regardless, because your IPW's and IFR's will not be the same.
as far as "too much" a friend of mine is running 60# in his 3400, and it doesn't seem to be too much for his setup (15+psi turbo)
11-08-2006, 11:09 AM
AutoCross Alero
i'll be tuning my 36'rs this weekend, my fuel system has been running lean with the stockers.
11-08-2006, 11:43 AM
good luck on that
11-08-2006, 04:20 PM
JB, your stockers should perform fine with the mods you have. You just need to bump up your IFR's a little. There's no way that anything less than boosted, nitrous, or serious rise in compression ratio will outflow your stocks.
You might be wringing a little more out of the duty cycle, but no chance of them going static on you.
11-08-2006, 05:46 PM
AutoCross Alero
they are already installed and everything is bolted together, so they are staying in, i'm bumping up to S/C soon anyways.
