Old 11-15-2006, 10:30 PM   #1
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
Aquamist
http://www.3sx.com/store/comersus_li...dCategory= 24
Don't hear much about them. Innovative invention or waste of money?
CiscoPath is offline   Reply With Quote
Old 11-15-2006, 11:28 PM   #2
Kilroy
Kilroy's Avatar
Kilroy is on a distinguished road
On a normal factory engine they are a waste. However, if you beef up your engine, increase the compression ratioe etc. etc. water water injection does is cool the combustion chamber, helping to prevent detonation. Also, since you are introducing a bit of water, and it is turned into steam by the heat of combustion, it actually increases the compresion slightly due to the expansion of the steam. BUT... as I said, on a normal engine with no modifications, it is a waste of money.
Kilroy is offline   Reply With Quote
Old 11-15-2006, 11:39 PM   #3
CiscoPath
CiscoPath's Avatar
So what kind of power would you have to be making to consider this kit viable?
Old 11-15-2006, 11:45 PM   #4
Probably more than an Alero will ever get
Old 11-16-2006, 12:45 AM   #5
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
and this is just because hardly anybody likes to put a ton of money into an Alero's engine.
if you are spending over $5k on your engine, it might be worth it to add that in. Other than that, no need to really consider it at all.
Old 11-16-2006, 12:59 AM   #6
CiscoPath
CiscoPath's Avatar
Gotcha. W/A Injection and Aleros just won't splice.
Old 11-16-2006, 07:54 AM   #7
any boosted application could benefit greatly from a good well-tuned w/a injection setup.....greg here in colorado runs water/meth injection? works fairly well
