Old 12-07-2006, 11:32 PM   #1
-Alero-
-Alero-'s Avatar
tire size.........wtf
i have a question and its bugging the hell out of me.
on a stock alero it can come in either 15's or 16's......my question is why are the tires 215/60/15 and 215/50/16
wouldnt that mean if your car came with the stock 15's and yo uchose 17's yo uwould have to use 50 series tires?
and if yoru car came stock with 16's and you chose 17's that would mean you would move to 45 series tires.
wtf is up with this. have i been running the wrong size tire all along? ( 225/45/17) mine came with 15's.
my geo has 175/65/14. that would mean if i had 17's on it i would have to have 50 series tires on it.
someone wanna explain this to me?
AUTOBOT
Old 12-07-2006, 11:38 PM   #2
CiscoPath
CiscoPath's Avatar
CiscoPath is an unknown quantity at this point
I never understood this stuff either.
CiscoPath is offline   Reply With Quote
Old 12-07-2006, 11:40 PM   #3
-Alero-
-Alero-'s Avatar
oh i understand the ratios. its just i dont understand why it skips 10 in series for 1 inch in rim. where it should only be 5 for every inch of rim.
AUTOBOT
Old 12-08-2006, 12:01 AM   #4
15 inch Alero tires are 215/60/15 and 16's are 225/50/16
It's the plus size factor to keep the tire overall size the same. Typically you would go 10 mm on the width and series (sidewall) when you go up an inch and going down in size is the same way
Old 12-08-2006, 12:01 AM   #5
FantomForceCustoms02
FantomForceCustoms02's Avatar
FantomForceCustoms02 is an unknown quantity at this point
Send a message via AIM to FantomForceCustoms02
215/45/17 would be be the same overall wheel diameter as stock. The numbers are a percentage. I think it's 215 mm wide and the side wall is 45% of the 215. Something like that. 225/45/17 is close enough to keep your speedo correct. it would be off by about 1%
www.fantomforce.com
I like mine SHAVED
Be my friend...
http://www.myspace.com/fantomforce
FantomForceCustoms02 is offline   Reply With Quote
Old 12-08-2006, 12:02 AM   #6
205/50/17's
Old 12-08-2006, 12:13 AM   #7
-Alero-
-Alero-'s Avatar
Originally Posted by Redog View Post
205/50/17's
uhhhhh..........
why is there a 10 series difference between 15's and 16's why isnt it a 5 series difference. thats what im trying to find out.
why shouldnt we have 50 series tires with our 17's when our cars will come with 60 series tires on 15's!?
AUTOBOT
Old 12-08-2006, 12:26 AM   #8
Some cars are different.
Alero's tire ratio's are "FUBAR" if you go with a 235/40/17 which in theory is the correct plus size.
Old 12-09-2006, 03:02 AM   #9
The Alero could come with either
215/60R15 25.2" dia (1999-2003)
205/65R15 25.5" dia (2004)
225/50R16 24.9" dia (1999-2004)
I used a 235/45R17 on mine.
Old 12-09-2006, 11:57 AM   #10
Alero2k4
Alero2k4's Avatar
Alero2k4 is an unknown quantity at this point
it is because the width is different. The '50' is an aspect of the 225, so because 225 is wider than 215, if it was a 215/xx/16 then it would need to be 55 but because it is 225/xx/16 it needs to be 50 if that makes sense....
1.3l Renesis Rotary
Alero2k4 is offline   Reply With Quote
Old 12-09-2006, 01:03 PM   #11
the actual math if that makes sense-
The tire size is calculated as the width (225) multiplied by the aspect ratio (.50), then doubled. Add that to the wheel size in mm (406.4). Divide that total number by 25.4 to get the overall tire diameter in inches. (24.9)
•225/50R16
2(225*.50)+(16*25.4)
225+406.4=631.4
631.4mm = 24.9"
Old 12-10-2006, 03:47 AM   #12
-Alero-
-Alero-'s Avatar
hmmm mines an 02 and it came with the 15's and im running 225/45/17's right now so you think im off?
so your saying the lower the profile the wider the tire needs to be?
im wanting to go back to stock 15's but i dont have tires on the rims. what size do i need? 205/65 or 215/60
AUTOBOT
Old 12-10-2006, 05:39 AM   #13
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
it's because it's a game of percents.
example:
225/50/16 (stock)
225 = tread width (mm)
50 = % of the tread measure for the height of the sidewall (which then equals 112mm)
16 = inches diameter of the wheel (x25.6 for the measurement in mm = 409.6)
for overall diameter of the tire, add the rim to the sidewall measurement (x2) which is 634.6mm
up it to 17" rims.
17" = 435.2
634.6-435.2=199.4
199.4/2=99.7
99.7 is the ideal sidewall measurement.
keeping the 225mm tread measurement:
divide the tread measurement by 100 (the result is 1%)
then divide the ideal sidewall measurement by the 1% amount. This result is the actual % of the tread measurement that the ideal sidewall measurement is. in this particular case, 44.3111%. Since tire companies only make tires in increments of 5% series, you'd have to go with the 45 series.
thus the upsize would be 225/45/17.
If that made sense, I amaze myself, because I am drunk. If it doesn't make sense, then you know why. lol
edit: I just realized that I always mix up the conversion for inches to metric. use 25.4, not 25.6. sorry.
Old 12-10-2006, 01:18 PM   #14
Try this on for size...
http://www.miata.net/garage/tirecalc.html
Old 12-14-2006, 07:04 PM   #15
-Alero-
-Alero-'s Avatar
god damn it my car is 2% too fast!?
my car probably doesnt have 69k on it then..........god damn it.
AUTOBOT
Old 12-14-2006, 07:54 PM   #16
jackal2000
jackal2000's Avatar
unless those miles were all highway then i dont think your odometer is too far off....
Old 12-14-2006, 08:02 PM   #17
-Alero-
-Alero-'s Avatar
err well i first started out by moving from the stock rim/tirss to 205/40/r17 for like 30k miles and now i have 225/45/17 wich are off......apparently
AUTOBOT
Old 12-14-2006, 09:14 PM   #18
Same size I have on my car, don't worry about it. I've driven past a few of those "You Speed" radar guns and the speedo is either dead on, or reads 1 mph faster
