Old 12-13-2006, 08:23 AM   #1
nhartwell
Cosmo Racing
Anyone have any input on Cosmo Racing Short Throw Shifters and WAI?
I was thinking I could return the B&M and buy these two things...
Old 12-13-2006, 01:30 PM   #2
nhartwell
together, those two things are cheaper than the B&M lol. And I get twice the performance... Same either way with the throw % and an extra few HP with a better Ram Air than my custom WAI.
Old 12-13-2006, 05:10 PM   #3
Spilner521
Boost Guru
Spilner521's Avatar
Keep the B&M. It's probably the best short shifter you can buy. No point in getting rid of a high quality part just to get another one of lower quality. Just get the new intake in addition to the B&M.
Old 12-13-2006, 08:30 PM   #4
nhartwell
how do u figure it is higher quality?
Same milling, same material.. different name.. Size is the same..
Old 12-13-2006, 08:32 PM   #5
nhartwell
the only thing that can be different is the box, instructions, and customer service..
Old 12-13-2006, 08:33 PM   #6
nhartwell
oh, and maybe mounting materials
Old 12-14-2006, 03:47 PM   #7
ptrudel
Designated Drunk
the cosmo isnt a short shifter!!!!! i bought one, looks awesome and all, but all it is is a shorter handle, not a shorter throw..that ebay thing is a POS
I'm baaaackk
Old 12-14-2006, 04:01 PM   #8
nhartwell
LAF^
The center ball join is like a fulcrum. And the shorter the handle is from the end to this ball join, the shorter the throws will be. This is a true short throw shifter. Hence all that makes a short throw is a shorter handle. There is no other type... This is the same as the B&M. There is no way if the handle is shorter, the throws are not shorter... Short throw is truly meant for ergonomics, not really performance...
Old 12-14-2006, 04:02 PM   #9
nhartwell
hence, if u cut ur standard shifter, it makes it a short throw...
Old 12-14-2006, 04:13 PM   #10
nhartwell
Let me show u...
Old 12-14-2006, 04:14 PM   #11
nhartwell
and if the handle is shorter, than that means between the top and central joint, because the joint cannot be moved for mounting reasons
So basically u are saying the B&M isn't a true short shifter... Because it works the same way and is the exact same size. Throws will not feel more than about 10% shorter, but u have to do the math with the ratio of ur own throw compared to the base. both ends. That is how they come up with their # of 30some percent.
Old 12-14-2006, 04:27 PM   #12
ptrudel
Designated Drunk
isnt the B&M a shorter distance between the2 "balls"(sorry for the lack of grammar, i've been workin in fumes for 8hours)
I'm baaaackk
Old 12-14-2006, 04:34 PM   #13
how bout if you are sold on the stupid thing... buy it... stop asking people about it so you can argue with them.
Old 12-14-2006, 04:35 PM   #14
nhartwell
negative, they cannot be different. Otherwise u would have to modify the mounting or the cable lengths.
if u shortened the distance between the balls, it would make for larger throw distances for the human, and little distances for the bottom. Meaning that would be a increased throw shifter haha.
no worries about the grammer. fumes from what?
Old 12-14-2006, 04:37 PM   #15
nhartwell
not arguing with them. I'm teaching...
now GTFO of the 2.4 threads...
Old 12-14-2006, 04:39 PM   #16
why can't i be on the 2.4 threads?
hey... weren't you the genious teaching everyone that the earth doesn't have any resources in it in the "moon" thread?
Old 12-14-2006, 04:50 PM   #17
nhartwell
yes i was, why? did u learn something?
Old 12-14-2006, 04:50 PM   #18
nhartwell
Because.. I said so..
Old 12-14-2006, 04:54 PM   #19
actually it did send my looking for something to prove you wrong... and i definately found it... oh... and i have a 2.4 also
Old 12-14-2006, 04:55 PM   #20
ptrudel
Designated Drunk
fumes from the engine swap i'm workin on on my 2.4...
I'm baaaackk
