Here is what GM recommends:
12 500 km (7,500 miles)
Rotate the tires. + *
25 000 km (15,000 miles)
• Inspect the air cleaner filter if the vehicle is driven in dusty conditions. Replace the filter if necessary. This is an emission control service. [Dagger]
• Rotate the tires. + *
37 500 km (22,500 miles)
50 000 km (30,000 miles)
• Replace engine air cleaner filter. This is an Emission Control Service.
62 500 km (37,500 miles)
75 000 km (45,000 miles)
• Inspect engine air cleaner filter if you are driving in dusty conditions. Replace the filter if necessary. This is an Emission Control Service [Dagger]
83 000 km (50,000 miles)
Change the automatic transaxle fluid and filter if the vehicle is mainly driven under one or more of these conditions:
• In heavy city traffic where the outside temperature regularly reaches 90°F (32°C) or higher.
• In hilly or mountainous terrain.
• When doing frequent trailer towing.
• Uses such as found in taxi, police or delivery service.
If this vehicle is not driven under any of these conditions, the fluid and filter do not require changing.
87 500 km (52,500 miles)
100 000 km (60,000 miles)
• Inspect the engine accessory drive belt. This is an Emission Control Service.
• Replace the engine air cleaner filter. This is an Emission Control Service.
112 500 km (67,500 miles)
125 000 km (75,000 miles)
• Inspect the engine air cleaner filter if you are driving in dusty conditions. Replace the filter if necessary. This is an Emission Control Service. [Dagger]
137 500 km (82,500 miles)
150 000 km (90,000 miles)
162 500 km (97,500 miles)
166 000 km (100,000 miles)
• Inspect the spark plug wires (except 2.4L Code T L4 engine.). This is an Emission Control Service.
• Replace the spark plugs. This is an Emission Control Service.
• Change the automatic transaxle fluid and filter if the vehicle is mainly driven under one or more of these conditions:
- In heavy city traffic where the outside temperature regularly reaches 90°F (32°C) or higher.
- In hilly or mountainous terrain.
- When doing frequent trailer towing.
- Uses such as found in taxi, police or delivery service.
If this vehicle is not used under any of these conditions, the fluid and filter do not require changing.
240 000 km (150,000 miles)
• Drain, flush and refill the cooling system (or every 60 months since the last service, whichever comes first).
• Inspect the hoses.
• Clean the following components.
- The radiator
- The condenser
- The pressure cap
- The neck
• Pressure test the cooling system and the pressure cap. This is an Emission Control Service
