Old 12-21-2006, 10:00 PM   #1
lilfee504
lilfee504's Avatar
lilfee504 is on a distinguished road
i want 2 bridge my amp
im runnin 2 memphis 10s with a sony explode amp 1200w, 500rms unbridged. now im thinkin about bridging the amp 2 see how much power i will get but i read around that bridging can blow the amp...so i mean should i or should i not?
lilfee504 is offline   Reply With Quote
Old 12-27-2006, 07:36 PM   #2
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
lose the sony amp-they suck
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 12-27-2006, 08:00 PM   #3
crazyalero
crazyalero is on a distinguished road
Send a message via AIM to crazyalero
x2!!!!!get rockfordfosgate
->Current Mods:CAI,S&S headers,High Flow Cat,2.5 pipe from headers back,maganflow Muffler,intrax springs,18" Chrome rims,MMS stage 2 performance package
crazyalero is offline   Reply With Quote
Old 12-27-2006, 08:49 PM   #4
whiteliquid
Defeat < Giving Up
whiteliquid's Avatar
whiteliquid is an unknown quantity at this point
Send a message via MSN to whiteliquid Send a message via Yahoo to whiteliquid
fosgate is good...but just do yourself a favor and go get a power acoustik goth series amp
And as for your ? you can do it....
WhiteLiquid
whiteliquid is offline   Reply With Quote
Old 12-27-2006, 09:19 PM   #5
SweetNLow
SweetNLow's Avatar
totally
joelsoundxtreme: u faggot
Old 12-27-2006, 09:25 PM   #6
Whats the model number?
Are you sure its not a mono amp? If it is, you cant bridge it. You can drop your impedance by varying the Ohm load, but thats done with your subs wiring.
Need sub info also. Memphis makes a few 10" subs, and Sony has made many 1200 amps...
Old 12-28-2006, 03:13 AM   #7
white04alero
get a new amp take the sony back to wal mart
Old 12-28-2006, 03:35 AM   #8
number1alero
number1alero is an unknown quantity at this point
x2...i also have a goth series power acoustik amp, and ive got it hooked up to a couple 800watt/400rms Kicker CompCVR's and i think ive blown one of the subs from the amp having too much power...despite it being matched up perfectly power rating wise (720watt rms/1channel @ 4 ohms) i really believe they are underrated
number1alero is offline   Reply With Quote
Old 12-28-2006, 10:21 PM   #9
lilfee504
lilfee504's Avatar
ha ha ha. i got it from best buy 3 years ago...didnt kno 2 much about radios and sounds back then...so i just grabbed it becuz it came with 2 10in duals((threw them away since they were flooded out))
Old 12-28-2006, 10:30 PM   #10
sound_xtreme
sound_xtreme's Avatar
rofl at the power acoustik goth people. IF ur gonna get power acoustik get the 3000D, settle for nothing less.
Cardomain
Old 12-28-2006, 10:31 PM   #11
lilfee504
lilfee504's Avatar
sony model number --- XM2200GTX 1200w
600 watts x 2 channels max
200 watts RMS x 2 @ 4 ohms
250 watts RMS x 2 @ 2 ohms
500 watts RMS x 1 @ 4 ohm
low-pass crossover (50-300 Hz, 12 dB/octave)
variable bass boost (0-10 dB at 40 Hz)
Tri-way capable
15-3/4"W x 2-3/16"H x 10-7/8"D
stereo 2 channel or bridged mono output
4-ohm stable when bridged
Tri-way capable
MOSfET power supply
preamp and speaker level inputs
preamp outputs
gold-plated connectors
memphis info----RMS/Peak (W)- 250/450
model number---15-PR104D
Dual 4-Ohm subwoofer
Old 12-28-2006, 10:35 PM   #12
sound_xtreme
ya bridge it. wire to 2 ohms each(parallel)(pos to pos, neg to neg), then wire the 2 teminals on the box in series(pos to neg on the box).
Cardomain
