01-05-2007, 01:18 PM
Water Pump is F*cked?
Timeline of events:
1 month ago.. replaced leaking and cracked water outlet
Yesterday.. Large puddle of antifreeze under car (back left side of engine)
I believe this is where the waterpump is located
Today.. Change Oil light came on along with Service Engine light 1000 miles short of 3000.
First, I think I need a new waterpump. I checked and the whole area is soaked and it looks like it is the waterpump leaking alot!
Second, how should I go about getting this fixed:
Professionally: How much will it cost
Myself: Parts needed + cost, ease of fix, time, and i understand it involves the timing.
Next, the change oil light and check engine light:
I made sure there was no water from the antifreeze coolant in the oil by checking for milky spots.
However, my oil is a quarter down.
Any suggestions?
01-05-2007, 02:18 PM
Which motor do you have, if you have the 3400 could it be the LIM gasket?
Change oil light, covered many times, reset button inside drivers side fuse box
01-05-2007, 02:20 PM
Aleromod.com > Performance Related > 2.4L Twin-Cam Specific
HEHE
01-05-2007, 02:33 PM
alright dude, the change oil light is no big deal, you just forgot to reset it when you changed the oil. Mine does that too, i just pop open the fuse box and reset it, so that problem is out of the way
cant really help you with the other stuff cause im a window licker
01-06-2007, 05:51 AM
window licker, hahaha, at least he admits it. Sounds like a water pump to me. Check the hood liner for coolant spray off the belt, that is the best way i know to find out for sure.
01-06-2007, 09:01 AM
Owner
if it is soaked where you say then probably is water pump. changing the water pump is no easy task. if you don't have a garage, lots of tools, jackS and good mechanical knowledge and skill then go to a shop. a water pump is like $60-$80 but for a shop to do it is like $600 only because a lot is involved.
Beware of the BackStabber
01-06-2007, 09:07 AM
Owner
Water Pump Replacement 2.4 L- Disconnect the negative battery cable.
- <LI type=1>Drain the coolant. Recover the coolant. Refer to Draining and Filling Cooling System .
- <LI type=1>Disconnect the electrical connectors.
- <LI type=1>Remove the exhaust manifold heat shield.
- <LI type=1>Remove the heat wrap from the heater hose.
- <LI type=1>Remove the coolant inlet housing bolt through the exhaust manifold.
- <LI type=1>Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
- <LI type=1>Remove the exhaust manifold brace-to-manifold bolt.
- <LI type=1>Remove the manifold-to-exhaust pipe studs.
- Remove the heater outlet pipe bracket-to-transmission bolt.
- <LI type=1>Remove the coolant inlet housing assembly- to-water pump cover bolt.
- <LI type=1>Disconnect the exhaust pipe from the exhaust manifold. Refer to Catalytic Converter Replacement in Engine Exhaust.
Important
Do not rotate flex coupling more than 4 degrees as damage may occur.
<LI type=1>Pull down and back on the exhaust manifold pipe in order to disengage the pipe from the exhaust manifold. - <LI type=1>Disconnect the coolant inlet pipe from the oil pan. Remove the pipe. <LI type=1>Lower the vehicle.
- <LI type=1>Remove the brake vacuum pipe from the cam housing.
- <LI type=1>Remove the exhaust manifold to cylinder head retaining nuts.
- <LI type=1>Remove the exhaust manifold. Refer to Exhaust Manifold Replacement in Engine Mechanical - 2.4L.
- <LI type=1>Remove the seals and the gaskets of the exhaust manifold.
- <LI type=1>Disconnect the heater hose quick connect from the heater outlet pipe.
- <LI type=1>Remove the front timing chain cover. Refer to Timing Chain Housing Replacement in Engine Mechanical - 2.4L.
- Remove the timing chain tensioner. Refer to Timing Chain, Sprockets, and/or Tensioner Replacement in Engine Mechanical - 2.4L.
- Remove the water pump cover-to-cylinder block bolts.
- <LI type=1>Remove the 3 water pump-to-timing chain housing nuts.
- <LI type=1>Remove the water pump and cover assembly.
- <LI type=1>Remove the water pump cover-to-coolant pump assembly bolts.
- Clean all sealing surfaces.
01-06-2007, 09:09 AM
Owner
- <LI type=1>Install the water pump cover to the water pump assembly.
- Install the pump cover bolts. Hand tighten the bolts.
- <LI type=1>Install the cover-to-block bolts. Hand tighten the bolts.
- <LI type=1>Install the coolant pump-to-timing chain housing nuts. Hand tighten the nuts.
- <LI type=1>Lubricate the O-ring on the coolant inlet pipe with an antifreeze solution.
- <LI type=1>Slide the pipe into the water pump cover.
- Install the bolts. Hand tighten the bolts.
- <LI type=1>Torque in sequence as follows:
- <LI type=A>Tighten the pump assembly-to-timing chain housing nuts. Tighten Tighten nuts to 26 N·m (19 lb ft).
<LI type=A>Tighten the pump cover-to-pump assembly bolts. Tighten Tighten the bolts to 14 N·m (124 lb in).
<LI type=A>Tighten the coolant pump cover-to-engine block bolts. Tighten the bottom bolt first. Tighten Tighten bolts to 26 N·m (19 lb ft). - Tighten the coolant inlet pipe assembly-to-coolant pump cover bolts. Tighten Tighten the bolts to 14 N·m (124 lb in).
- <LI type=1>Install the exhaust manifold and install new gaskets. Refer to Exhaust Manifold Replacement in Engine Mechanical - 2.4L.
- <LI type=1>Install the exhaust manifold-to-cylinder head retaining nuts.
- <LI type=1>Connect the brake vacuum pipe to the cam housing.
- <LI type=1>Index the exhaust manifold bolts into the exhaust pipe flange. Refer to Catalytic Converter Replacement in Engine Exhaust.
- <LI type=1>Install the exhaust pipe to the exhaust manifold.
- <LI type=1>Install the heater outlet pipe bracket to the transmission.
- <LI type=1>Turn exhaust both bolts in evenly in order to avoid roostering the exhaust pipe and binding the bolts. Turn in the bolts until the bolts are fully seated.
- <LI type=1>Install the coolant inlet pipe to the oil pan. Tighten Tighten nuts to 26 N·m (19 lb ft).
<LI type=1>Install the timing chain tensioner. Refer to Timing Chain, Sprockets, and/or Tensioner Replacement in Engine Mechanical - 2.4L. - <LI type=1>Install the timing chain cover. Refer to Timing Chain Housing Replacement in Engine Mechanical - 2.4L.
- <LI type=1>Lower the vehicle. <LI type=1>Install the exhaust manifold brace to the manifold bolt.
- <LI type=1>Install the manifold to the exhaust pipe nuts. Refer to Catalytic Converter Replacement in Exhaust System.
- <LI type=1>Install the heater hose to the heater pipe.
- <LI type=1>Inspect the quick connect retainer. Pull on the heater hose in order to verify the connection.
- <LI type=1>Install the upper heat shield to the exhaust manifold.
- <LI type=1>Connect the oxygen sensor connector.
- <LI type=1>Fill the radiator with coolant. Refer to Draining and Filling Cooling System .
- <LI type=1>Connect the negative battery cable.
- Inspect the system for leaks.
