Old 03-25-2004, 02:47 PM   #1
supvnman
my alero is still under warranty. I took my car in cause the power steering pump blew. while there i had them check out a ticking noise in my engine (3400). turns out my crankshaft was "bent" (i think they just ment out of balance) and the main bearings were gone. they replaced the entire engine with a brand new one.
I was just wondering if there is some sort of break in period. the mechanic told me to change the oil after the first 500 miles then i should be fine, but ive heard some mixed reviews on what u should do.
Old 03-25-2004, 04:01 PM   #2
No hard throttles for about 500 or 1000 miles.
Don't stay at one speed for a long period of time for the first 500 miles.
Old 03-25-2004, 05:39 PM   #3
BLK03GXS
BLK03GXS's Avatar
Ditto, Take it easy, prolly no more than 1/2 throttle, stay under 110 kph for extended periods, change at 500, baby it :thumbsup:
Old 03-25-2004, 05:41 PM   #4
Final-Reality
Are you sure it's a "new" engine? If it was they probably would've given you break in instructions. It probably isnt a 0-mileage engine and is thus already broken in. Call them and ask.
Old 03-25-2004, 06:25 PM   #5
BLK03GXS
BLK03GXS's Avatar
yea... it could verry well be a low milage used motor... you would want to find that out.. for sure
Old 03-25-2004, 06:49 PM   #6
b-spot
b-spot is an unknown quantity at this point
Aren't you supposed cover the whole rev band when breaking in to expose the seals to a wide temp range?
I thought babying it all the time was bad.. for the most part yes, but rip 'er a couple times too
If I did went to college...
b-spot is offline   Reply With Quote
Old 03-25-2004, 07:20 PM   #7
Aleromaster
Aleromaster is an unknown quantity at this point
Send a message via AIM to Aleromaster Send a message via Yahoo to Aleromaster
I always break in as I normally drive it and I had a car last me 200,000 miles. The otherones I got rid of either due to body problems or one was totaled so I never had problems with my engins
2002 GL2 4DR, MYMODS:In dash 7&quot; VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10&quot; Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
Aleromaster is offline   Reply With Quote
Old 03-25-2004, 07:56 PM   #8
jturkey69
jturkey69's Avatar
jturkey69 is an unknown quantity at this point
Send a message via Yahoo to jturkey69
if it is a brand new engine...there is a process i do to all my new engines called "seating the rings"....heres how to do it..........from a dead stop...put the car in low gear, and accelerate normally to about 3000 to 3500 rpms, and let off totally and let the engines compression drag itself back down to nothing, reapeat this 3 or 4 times...what this is doing is when you let off the gas and use the mototr to slow you down...your forcing the piston rings to expand and push themselves into the cylinder walls,, and yes...nothing above 4000 rpm for the first 1000 miles or so....the main reason you want to change the oil at 500 miles is to get rid of all the different assembly lubes used throughout the engine building process.......granted all this is if the motor is actually new
OCA Alero Chapter Member!!!!
ALERO-LESS
jturkey69 is offline   Reply With Quote
Old 03-25-2004, 10:31 PM   #9
Final-Reality
You could probably search google for a million different break-in "tips"...
Old 03-30-2004, 02:04 PM   #10
supvnman
yes its a new motor. thank u guys for the help. u all helped more than my search engine searches.
