Old 01-06-2007, 04:53 PM   #1
myowneq
myowneq is an unknown quantity at this point
HVAC Lights
Alrighty, here's one for the group.
I want to change the lights on my HVAC unit to the red LEDs. I pulled everything apart and *gasp*, the lights are soldered on the board. I have the skills to take everything apart and I'm sure I can solder the LEDs back on, but by chance, does ANYONE know the voltage on the circuit board for these lights? It would be greatly appreciated.
Thanks,
Timothy
myowneq is offline   Reply With Quote
Old 01-06-2007, 05:30 PM   #2
sound_xtreme
sound_xtreme's Avatar
why bother doing that?
jus break the bulbs(or just find which wire is giving voltage to em and snip it) and just wire up led's to the dimmer switch
Cardomain
Old 01-06-2007, 05:37 PM   #3
2fst4u
[boosted 2.4L]
2fst4u's Avatar
why don't you hook it back up and throw a voltmeter on it? too easy, really.
Old 01-06-2007, 05:49 PM   #4
myowneq
Because almost everytime I hook up a voltmeter, I blow them up. And not a little poof either, but a great big one.
Sound Xtreme, I like my work to look as original as possible. I don't like extra wires running all about. Thanks though.
Old 01-06-2007, 10:21 PM   #5
myowneq
So,has anyone ever tried to change out these lights? I think i got an issue here.
Old 01-06-2007, 11:54 PM   #6
GoldStar611
GoldStar611 is on a distinguished road
a volt meter wouldn't blow anything..at least it shouldn't... now a test light maybe...I've seen the lights you're talking about, just touch the pins of the LED to the bulb pins (or to the traces on the back of the board) and see which side works the led. alternatively you could see which traces are grounded (using a continuity tester)
GoldStar611 is offline   Reply With Quote
Old 01-07-2007, 12:39 AM   #7
myowneq
Goldstar, so far, I haven't blown this one up. *knock on wood*
On the other note, I have tried tracing using the continuity tester, that is more confusing than a bowl full of spaghetti. It seems everything is connected to everything. I know three things for sure. The grey wire is positive for the dimmer switch and the black is the ground and there are eight bulbs on that particular path.
Old 01-08-2007, 02:54 PM   #8
El_Diablo
just use a resistor to drop from 12v
Old 01-08-2007, 08:55 PM   #9
myowneq
Ok, update on this one. After all said and done, I ran out of LEDs after blowing a few up. Of the eight bulbs on the board, I was able to replace five. What a hell of a project. The problem I was having was how to fit the LED AND the resistor into two small holes without shorting something out. The I had to use hot glue to keep the + and - seperated.
It does look good so far, however, the blue stripe on the temp control does not light up at all now. Not sure what to do on that one yet. Ideas?
Thanks,
Timothy
Old 01-08-2007, 09:01 PM   #10
Ghadsphi
The Drunk
Ghadsphi's Avatar
Ghadsphi is an unknown quantity at this point
Get someone with really small steady hands to do it! hehe
Ghadsphi is offline   Reply With Quote
Old 01-08-2007, 10:10 PM   #11
GoldStar611
oh, I thought you blew out the incandescant blubs..you're talking about blowing the LEDS..I see where you're comming from now. yeah, you may want to use only one of the positive traces and use a program to calculate the resistors needed to run the leds in parallel from that one positive wire.http://led.linear1.org/led.wiz
the forward voltage is usually around 1.2v (unless you have high intensity lights, and forward current usually around 20mA check out www.lsdiodes.com)
I wouldn't try to shove everything into the original spot..use a little bit of wire and remember heat strink tubing + lighter is your friend.
Old 01-09-2007, 09:57 PM   #12
myowneq
I think you two got me confused. I already figured out how to wire the LEDs into the existing system. However, if you look on the console piece on the temp control, you see the blue fade into red. During the daytime, you can tell. At night, the heat lights up, but the blue portion doesnt.
That's what I need ideas on.
Old 01-10-2007, 09:53 PM   #13
GoldStar611
Why not use a white led there..
Old 01-12-2007, 10:09 PM   #14
myowneq
I would have to fabricate a blind to limit the white light from spreading everywhere. Not sure how to accomplish that one yet.
Old 01-12-2007, 11:11 PM   #15
wrap some electrical tape around the LED????????
Old 01-13-2007, 04:59 PM   #16
El_Diablo
heat shrink would be better, but whats the point? LED's are pretty much aimed anyways... just get narrow viewing angle LED's
Old 01-13-2007, 05:00 PM   #17
sound_xtreme
liquid electrical tape
Cardomain
Old 01-13-2007, 08:14 PM   #18
myowneq
Hmmm.. I don't know, but I'll give it a try when I'm back onshore. I've got plenty of LEDs to play with.
