Old 01-18-2007, 10:30 PM   #1
whiteliquid
Defeat < Giving Up
whiteliquid's Avatar
whiteliquid is an unknown quantity at this point
Send a message via MSN to whiteliquid Send a message via Yahoo to whiteliquid
Question about interior.
Does anyone know if you take the vinyl off the dash and door panels how well the plastic holds paint.
WhiteLiquid
whiteliquid is offline   Reply With Quote
Old 01-18-2007, 11:57 PM   #2
good question...... I don't have the answer for ya though..... I would like to know as well.
Old 01-19-2007, 12:29 AM   #3
racin4JC
racin4JC's Avatar
racin4JC is an unknown quantity at this point
Assuming you can get all the vinyl and padding off and glue, the plastic is actually textured so you will probably want to sand it, but paint would stick well. However, most of your vents and trim are not going to fit correctly when you go to put it back together because you just took off like 1/4in. thickness off of your dash and the vinyl is pulled all the way behind your vents and then glued really well. (Hopefully what I am saying makes sense to you, my dash is fiberglassed so I know how all the pieces go together and how you have gap issues after you remove the vinyl and padding).
racin4JC is offline   Reply With Quote
Old 01-19-2007, 12:50 AM   #4
sound_xtreme
sound_xtreme's Avatar
if you pull that vinyl off, not only will the vents "not fit perfect" they wont fit at all to be honest.
Cardomain
Old 01-19-2007, 02:00 AM   #5
Vinalero
Vinalero's Avatar
one of my friends redone the interior of his 300zx. He pulled all the carpet that was in place on the doors and everywhere (strange that there was carpet all over the dash) and made some vinyl pieces out of them by taking the shapes of all the carpet pieces
Take a look at his Cardomain page : http://www.cardomain.com/ride/2479846 and look the third page for the difference btw before and after.
Old 01-19-2007, 09:51 AM   #6
whiteliquid
Defeat < Giving Up
YEa i figured that about the vents and other stuff.....A little glass work for me then i guess.
What i was really worried about was how well that plastic would hold paint.
Thanx
WhiteLiquid
Old 01-19-2007, 11:58 AM   #7
racin4JC
racin4JC's Avatar
If the plastic was perfectly clean and smooth it would hold the paint, it is probably more of an issue to get the plastic to hold the fiberglass (make sure you drill holes in dash and sand very thoroughly with like 60 or 80 grit before you start glassing).
Old 01-19-2007, 12:36 PM   #8
sound_xtreme
Thanx
if your just going to touch it up you cant use glass. youll have to use plastic repair(which still probably wont work). if ur gonna glass the whole thing, gotta drill a bunch of holes and rough the hell outta it.
Cardomain
Old 01-19-2007, 02:14 PM   #9
AftermathAlero
whiteliquid .. by rough joel mean, use a air grinder or electric grinder w/ 36 grit. but don't burn though the plastic. LOL
Old 01-19-2007, 02:53 PM   #10
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
^ if I remember correctly, is that so it will actually stick, because glass doesn't stick to plastic well?
dumbing it down....makes it easier for n00bs to understand....lol
Old 01-19-2007, 04:26 PM   #11
whiteliquid
Defeat < Giving Up
I may just leave it the way it is....Im to lazy to take off the old paint and just re-paint it. And dont really have the time to dedicate to glassing it right.
Doesnt look bad....its just not "show worthy"
WhiteLiquid
