Old 11-18-2003, 09:58 PM   #1
3.4Alero
Originally posted by PaulVS+--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (PaulVS)</td></tr><tr><td id='QUOTE'>Okay... after the dreaded noise came back, the dealer 'fixed' it for 2 weeks by disassembling the caliper, lubing it, and putting it back. But now the sound is back.
It's only when I brake. Not when I coast to a stop. It's the right rear wheel only. Rotors and pads were replaced, but the noise keeps coming back. "reeeeek... reeeek.... reeeeek."
Yahoo Alero Groups has about 6 people posting the same problem, but no solutions.
http://autos.groups.yahoo.com/group/Alero/message/6113
Any guesses?[/b]
_________________
Originally posted by Jordan+--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Jordan)</td></tr><tr><td id='QUOTE'>Replace caliper. Get tech to do it to feel safe. [/b]
Originally posted by dbailey
Yeap, I'm hearing it on my 2000 too. Very annoying! I'm hoping that by going with an aftermarket caliper will be the fix. Has anyone had the problem and fixed it with an aftermarket caliper????
Is there an aftermarket caliper that doesn't cost $1000?
Originally posted by misslindseysue
I got a re-manned caliper for like $30 when mine was leaking. Works great.
Were you experiencing that annoying sound too?
That's not why I changed it. The cylinder was leaking brake fluid. I replaced a hub for annoying noises, but that was constant, not just when stopping. And my snow tires whine on smooth pavement, but once again, not brake related.
So I really have no idea what your problem is. But you can get a caliper for less than $1000.
Maybe make sure your wheels are balanced? Could be rotating funny, or something.
Had the wheels checked for out-of-round and balance - they're fine.
Weird thing is... that it disappears for a week or two at a time and then comes back.
That was kinda the way mine was doing too but recently its there all the flippin time!
Front or rear?
Front as far as I can tell.
<!--QuoteBegin-kicker
Sounds like the problem I had and now have again on a different wheel. It's definetly the caliper. A guy on this forum told me the piston seal busted on the caliper, so I replaced the caliper and no more brake creak. I'm sure a new caliper will fix your caliper and it should cost you around $100 to buy and you can usually return the busted one and get around $40-$50 back. [/quote]
<!--QuoteBegin-PaulVS
The dealer still has my car... The GM tech hotline told them they need to use a 'permanent' type lubricant on the caliper sliders. (sounds like hooey to me.) They have to order the lubricant.
The service manager disagrees with them.... he thinks it's the rear swaybar making noise, which is crap because it only happens when I brake, and it doesn't happen if I come to a stop using the emergency brake, or coasting to a stop, AND it doesn't happen in any other situation.
Might be time to trade the beotch in on a Stratus R/T.
[/quote]
Old 12-05-2003, 01:34 PM   #2
Redddog88
I had the same problem on mine. I found the culpret.....when you remove you pad from you caliper there is a grove it slides in. I looked at the grove and there is a piece of metal there that has been warpped and when I hit my brakes it rubs against the bottom of the pad.....So all I did was take a file and filed that piece down to make it smooth and then no more problem.......
Old 02-06-2004, 05:45 PM   #3
VPLaVarnway
99% of the time you hear the reeeekk is the pads vibrating in the housing....and the "permenant"type lubricant you can get at a parts house....it's described as a brake squeel stopper.....it just keeps the pad from vibrating soo much....it's not a serious problem or sway bar problem it's just annoying and it's caused by not bending the lil aluminum brackets that help hold the pad in the housing....now....you can get a squeeling sound when it is time to change your brakes.....they are called brake warners.....it's a lil metal thingy that rubs the cailpers when your brakes wear down so far....it doesn't hust anything but your ears....i hope that clarifies things for a lot of you...if not....keep asking me
Old 02-06-2004, 05:59 PM   #4
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
I hear this squeal from the front right wheel...and it's the only wheel that's really damn dirty (looks almost like is got a gun-metal finish). Funky thing is, I only have the squeal when I'm driving in idle. Once I'm going, though, it doesn't squeal. Is this just that vibration thing or is there something else to it? I doubt it's a "warner" because all the parts in that part of the car are brand new OEM parts from July (replaced because of the accident)
Old 02-07-2004, 01:21 PM   #5
PaulVS
I guess I forgot to put the 'finale' on this story...
Took it back to the dealer - and told them I hit the curb - they sent it to the body shop guys.... who found out the knuckle was bent.
They replaced the whole knuckle for $750.00. Problem fixed.
Live and learn.
Old 02-07-2004, 02:21 PM   #6
King Asoka
King Asoka's Avatar
I had the brake ceek too. But it was caused by warped rotors. I changed those pupies out and the no more ceek.....
Old 02-11-2004, 09:08 PM   #7
mykah89
im not too how should i say fluent with car terms yet but what is the knuckle, i beat the hell out of my brakes, when driving and not doing anything i can hear a tsst tsst tsst intervulled scraping noise from the front wheels i believe and when coming to a stop from not going very fast my brakes squeel like all hell. i think it also is those metal clippy things in the front but i am confused as to how to file them or what not any more in depth explanation would be appreciated
Old 02-11-2004, 09:34 PM   #8
3.4Alero
The "tsst tsst tsst" sounds like warped rotors. The squealing sounds like you need new pads. Plus you said you beat the hell out of your brakes. Do yourself a favor and get new pads and rotors.
