Go Back   Aleromod.com > Main Forums > New Member Introductions
Old 01-21-2007, 12:59 PM   #1
sanpa
won't start
my 01 alero quit on the free way the engine turns but do not start,timing belt maybe? is a v6 engine thanks for any info
Old 01-21-2007, 01:00 PM   #2
shiny alero
shiny alero's Avatar
shiny alero is on a distinguished road
Send a message via AIM to shiny alero
possible fuel pump
shiny alero is offline   Reply With Quote
Old 01-21-2007, 01:03 PM   #3
jackal2000
jackal2000's Avatar
need more info bud. any dashboard lights come on? if so which ones? can you hear the fuel pump turn on?
Old 01-21-2007, 01:45 PM   #4
sanpa
won't start
this 01 alero v6 has 115,000 miles the fuel pump is funcioning it has gas in the tank and i can see all the lights in the dash are on, before this car will quit any where' so this guy pull up a code and the car been runing fine since about a year. you know i replaced the front hubs, the signal lights click when they want, i also repleced pads and rotors and the list goes on but this time i'm no sure what the problem is thank you for your help
Old 01-21-2007, 03:26 PM   #5
teflone
teflone's Avatar
teflone is an unknown quantity at this point
Fuel..
I would guess fuel pump is not pumping fuel..
But if your absolutly certain , then you proabably dont have spark
Coil packs maybe... check for spark off each plug. if you know how to do this..
Try to grab some codes off your computer from a mech. it might suggest a route to check..
teflone is offline   Reply With Quote
Old 01-21-2007, 08:21 PM   #6
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
check and see if u got spark, then fuel. Do u have keyless entry? ur theft system maybe messed up and it lets the car crank but not start
