Old 02-19-2007, 02:39 AM   #1
stealthlero
stealthlero is an unknown quantity at this point
Send a message via MSN to stealthlero
Gauge Lights
A while back I put some Halo gauges into my car and for the power I just hooked them up to the light thats connected to the PRND321 lights next to the shifter. The gauges worked just fine and were bright as hell but now they are pretty dim and the dimmer switch is turned all the way up and the shifter lights aren't dim at all either.... any input would be great, thanks!!
stealthlero is offline   Reply With Quote
Old 02-19-2007, 02:45 AM   #2
MixtapeMessiah
Southern Fly Boy returns
MixtapeMessiah's Avatar
make sure u have a good connection, over time and goin over bumps and shit it might have gotten loose
Old 02-21-2007, 03:29 AM   #3
stealthlero
are there any other ideas for the cause of this problem? could it possibly be a blown fuse somewhere so it's just not getting enough power?
Old 02-21-2007, 02:01 PM   #4
Vinalero
Vinalero's Avatar
If a fuse was blown, my thought would be that it wouldn't light at all.
Old 02-21-2007, 02:11 PM   #5
greenbastard
greenbastard's Avatar
greenbastard is an unknown quantity at this point
recheck all your wiring. if you do that you might find the problem. a pinched wire or bad connection for example.
01 Alero GX 3400 swapped
v8 swapped 84 s10
greenbastard is offline   Reply With Quote
Old 02-21-2007, 02:45 PM   #6
diablo
diablo's Avatar
diablo is on a distinguished road
thats y it took so long for them to hook up mine cause they needed to get the wiring right, ***im sure its loose wiring***
diablo is offline   Reply With Quote
