Old 02-22-2007, 10:42 PM   #1
DaRockwilder
DaRockwilder's Avatar
DaRockwilder is on a distinguished road
Rear Disc Conversion
Hey!
I've searched here for threads about doing rear disc conversions, and I know what parts I need, etc, but I have a couple other questions not yet covered.
My car doesn't have ABS. I just want to double check that all the parts will still work properly, I just don't plug the hub in. Do drums require more fluid pressure to operate than a disc brake, or vise versa? My proportioning valve has no electrical connections on it like the one for ABS does, so its at a set metering. Just hoping the rears aren't going to lock up way before the fronts. Any input?
Are there any larger components I could use instead of the stock stuff? I know you can use F-body parts on the front, and a thread mentioned the possibility of using F-body parts on the rear as well but nobody reported back. I'd rather buy new bigger stuff than buy new stock stuff if I can.
Thanks for anything!
DaRockwilder is offline   Reply With Quote
Old 02-23-2007, 01:47 AM   #2
The F-Body stuff on the rear would require some serious fabrication.. I checked it out. (gotta love working at the parts store)
Old 02-23-2007, 02:02 AM   #3
strtrydr
strtrydr's Avatar
SSBC has a complete Rear Disc-Brake Conversion.
http://stainlesssteelbrakes.com
They are great quality and from what I understand definitely worth the expense.
Old 02-23-2007, 07:36 AM   #4
BadFrog
BadFrog is an unknown quantity at this point
Send a message via MSN to BadFrog
disk brakes require more fluid but the difference in required pressure pressure isn't significant, as long as your master cylinder and fluid resevoir is the same as one for 4 wheel disks you should be able connect them without having issues
BadFrog is offline   Reply With Quote
Old 02-23-2007, 03:47 PM   #5
Alero2k4
Alero2k4's Avatar
Alero2k4 is an unknown quantity at this point
also if you really needed to you could get a proportioning valve for the rears and most people just install it underneath the car
1.3l Renesis Rotary
Alero2k4 is offline   Reply With Quote
Old 02-23-2007, 03:56 PM   #6
DaRockwilder
Its my understanding that the master cylinders are the same. Thanks all!
