Old 03-01-2007, 08:18 PM   #1
shiny alero
shiny alero's Avatar
shiny alero is on a distinguished road
Send a message via AIM to shiny alero
sprung a leak
i noticed that no matter what, my carpets were becomming very wet, even in the back were no one sits. today i lifted the carpet and to my surprise under the padding was completly soaked, puddles and everything...i seen on the drivers side in the back there is a black hose...what is it? has any 1 had this problem...its the drivers side and sometimes the front passanger
shiny alero is offline   Reply With Quote
Old 03-01-2007, 08:20 PM   #2
the body has to be resealed from underneath.
Happened to mine, fixed under warranty
Old 03-01-2007, 08:27 PM   #3
shiny alero
hmm. recal warranty by anychance? i only have powertrain, AC, and heater warranty
Old 03-01-2007, 08:47 PM   #4
Ouch.
Should be that hard to fix, it's just finding the hole which is probably the size of a pea.
If you have access to a lift, might be easier to see
Old 03-01-2007, 08:51 PM   #5
shiny alero
yeah i do, just a matter of not being worn out after working 12 hours n staying late, would silicone seal the whole enugh?
Old 03-01-2007, 10:01 PM   #6
greenbastard
greenbastard's Avatar
greenbastard is an unknown quantity at this point
gasket maker!!! i used for everything on my winter beater. it's holding my service plate for my clutch and sealed my spoiler. it stinks but works great.
01 Alero GX 3400 swapped
v8 swapped 84 s10
greenbastard is offline   Reply With Quote
Old 03-02-2007, 12:53 AM   #7
you'd be better off using the correct seam sealer instead of an RTV. RTV can promote corrosion where the seam sealer is designed to be in places like that.
