Old 03-05-2007, 11:47 AM   #1
daiglepatrick
daiglepatrick is an unknown quantity at this point
break problems
I need to replace my front rotors and I noticed that my caliper slider pins are not sliding ( a bit rusty and I think the slider pin boot is riped)....do I need to replace the slider pins and caliper mounting bracket or can I simply lube them up with grease?
I checked at the dealer and the brackets are $106 CDN each....didn't check for the pins. and I read that the boots are around $15 each
daiglepatrick is offline   Reply With Quote
Old 03-05-2007, 11:56 AM   #2
Mr_Reed
Mr_Reed's Avatar
Mr_Reed is on a distinguished road
Send a message via AIM to Mr_Reed
I got breaks/rotors and new calibers for 400 bucks at BIG 10 Tires and it's all Wagner and life time warranty
Live to Ride
Ride to Die
Mr_Reed is offline   Reply With Quote
Old 03-05-2007, 12:39 PM   #3
I guess it all depends on how easy it is for you to get the pin out. Check out the condition of the pin and bracket. It's possible to clean the pin up (wire brush) and remove all the rust, make sure it slides in and out of the bracket easy, but not sloppy. Apply a liberal amount of grease to it and a new boot and it should be ok. Even if you wanted to just use a new pin, they should be available at most parts stores.
Old 03-05-2007, 02:22 PM   #4
daiglepatrick
Thanks for the info guys....I called around and I can get the pins for around $12 per set...and the brackets for around $15 each used ($106 new at dealer). also I think the boots come with the brackets, so if they're in good conditions I won't have to buy them.
Any recomendation for rotors....in CANADA. I've called around and they range from $25-$110 and $210 at the dealer.
Old 03-12-2007, 08:10 PM   #5
FrankNY
FrankNY's Avatar
FrankNY is an unknown quantity at this point
Send a message via AIM to FrankNY
Another source
Try: http://www.rockauto.com/
FRANK
2001 Alero GL
FrankNY is offline   Reply With Quote
Old 03-13-2007, 10:46 AM   #6
NibCrom
Originally Posted by FrankNY View Post
Old 03-13-2007, 10:55 AM   #7
antichrysler
For whatever it's worth if you're in Saskatoon I can get you 20% off at the dealership or some sort of discount at partsource. My dad owns a courier company and they do alot of business with them so I get a discount based on how much margin they have.
I bought new rotors/calipers for mine. Calipers were $151 and got em knocked down to $94, Rotors were $147 and got em knocked down to $90, Pads were $120 and got em knocked down to $63. All wagner.
Not sure if those are the best prices, I just went by the dollar discount and the fact I needed them that day.
Old 03-13-2007, 10:57 AM   #8
jackal2000
jackal2000's Avatar
brakes?
Old 03-13-2007, 10:58 AM   #9
greenbastard
greenbastard's Avatar
greenbastard is an unknown quantity at this point
my brakes grind super bad but i'm getting a loan to fix my car.
01 Alero GX 3400 swapped
v8 swapped 84 s10
greenbastard is offline   Reply With Quote
Old 03-13-2007, 11:34 AM   #10
Ghadsphi
The Drunk
Ghadsphi's Avatar
Ghadsphi is an unknown quantity at this point
Originally Posted by jackal2000 View Post
brakes?
Damn you! My brakes used to sound like a jet engine, now well they don't... But that's ok cuz they look nice... Just need do paimt those drums in the back...
Ghadsphi is offline   Reply With Quote
